STARTING HELP!!!
  • Thread starter Thread starter LxVert
  • Start date Start date May 8, 2007
L
LxVert
80
  • May 8, 2007
Hey guys
So today I just finished converting my car from Auto to 5spd. When i went to start my car to take it for a test drive, as soon as i put the key in the ignition and turn it to the point were only the dash lights should come on along with the radio the starter engages and the car will start with the starter still spinning in attempt to start. It begins to start before i ever even turn the key to the start position. please help
HISSIN50
34
129
May 8, 2007
  • May 8, 2007
Look for a crossed ignition wire. The S-terminal wire might be powered by a key-on source, rather than in the'crank' only position. This could happen at the ignition switch itself or at the safety switch (if you did any wire splicing).
Depending upon how you spliced or rewired things, if the issue goes away when you take your foot off the clutch, that's telling (if it goes away, the issue is before the safety switch. If the starter keeps spinning after taking your foot off the clutch, the issue is likely after the safety switch. This assumes the switch is functional).
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 9, 2007
  • May 9, 2007
Some diagrams of the ignition switch and starter circuits may be helpful...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
L
LxVert
80
  • May 9, 2007
Thanks for the help guys, it ended up being that when i spliced a couple wires together two of them had a bare spot and were touching, once i wrapped them up the car started perfect
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
