starting problem
  • Thread starter Thread starter slow93
  • Start date Start date Mar 19, 2006
slow93
406
  • Mar 19, 2006
i did a battery relocation on my car and it did fine for awhile..the problem i have now is after the car runs for awhile, if i shut it off it wont start again..it starts fine first thing in the morning or if i let it sit for an hour or so..i have since done a 3g alt. upgrage,new battery and new starter and nothing has helped..does anyone have an idea of what could be wrong..i have checked all the grounds and replaced the parts listed above in order to try to find out what is going on..i am out of ideas so any help would be appriciated
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Mar 19, 2006
  • Mar 19, 2006
what about the starter solenoid???
slow93
406
  • Mar 19, 2006
i didnt even think of trying that..could that cause that sort of problem
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Mar 19, 2006
  • Mar 19, 2006
i have had time where it would start and tapped it or fooled with the wire and it started up.
slow93
406
  • Mar 19, 2006
acually when it warms up it acts like the battery is dead. it will turn over real slow but just dont have enough kick to start.i will replace the soilinoid just incase though, it prolly needs a new one anyways
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Mar 19, 2006
  • Mar 19, 2006
what kind of started did u get?? is it the mini starter???
slow93
406
  • Mar 19, 2006
its just a factory replacement from autozone
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 19, 2006
  • Mar 19, 2006
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Mar 19, 2006
  • Mar 19, 2006
yup mine to. ive had problem with it. ill never buy another starter from autozone. sometimes u have to get 2 or 3 to get one that worth a siht.(happened to plenty buddy) im going to invest in a high torque mini starter next time.
slow93
406
#10
  • Mar 19, 2006
  • #10
i just had a thought, would heat mess with the resistance on the power cable coming fromthe back? in one spot it is kinda close to the exaust,could that be an issue or not
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 19, 2006
#11
  • Mar 19, 2006
  • #11
Use a DVM to measure the voltage at the battery while cranking and then at the starter solenoid to answer you question. There should not be more than .5 volt difference.
Here's a checklist:
here's my recommendation on rear mounted battery wiring.
Rear mounted battery ground wiring. Follow this plan and you will have zero ground problems.
One 1 gauge or 1/0 gauge wire from battery negative post to a clean shiny spot on the chassis near the battery. Use a 5/16” bolt and bolt it down to make the rear ground. Use a 1 gauge or 1/0 gauge wire from the rear ground bolt to a clean shiny spot on the block.
One 4 gauge wire from the block where you connected the battery ground wire to the chassis ground where the battery was mounted up front. Use a 5/16” bolt and bolt down the 4 gauge engine to chassis ground, make sure that it the metal around the bolt is clean & shiny. This is the alternator power ground.
The computer has a dedicated power ground wire with a cylindrical quick connect (about 2 ½”long by 1” diameter. It comes out of the wiring harness near the ignition coil & starter solenoid (or relay). Be sure to bolt it to the chassis ground in the same place as you bolted the alternator power ground. This is an absolute don’t overlook it item for EFI cars
Picture courtesy timewarped1972
Crimp or even better, solder the lugs on the all the wire. The local auto stereo shop will have them if the auto parts store doesn't. Use some heat shrink tubing to cover the lugs and make things look nice.
DKeen
43
#12
  • Mar 19, 2006
  • #12
my battery is in the trunk, and my car is very hard to start, I need to figure this out too.
91lxttrim
194
AZ
Mar 19, 2006
#13
  • Mar 19, 2006
  • #13
I just went through this same thing after I installed a trunk mount battery, electric fan, and intank and T-Rex fuel pumps. I lowered the fuel pressure to stock and installed a 2ga. ground cable going from the front of the engine block to the same location as the grounds stated in the post above (where the stock battery used to be). The car actually cranks faster and I haven't had any problems since!
Did you ground your battery in the trunk? I think the length of power cable to the solenoid might have something to do with it. That and the fact that the gound from the block to firewall is weak.
slow93
406
#14
  • Mar 20, 2006
  • #14
my power cable is just long enough to reach the soilinoid, i also ran a ground from the block to the computer ground.the only wire that i dont have is from the ground on the battery to the front, i have it grounded to the quad shock mount..
Jkstang78
1,510
long island N.Y.
Mar 26, 2006
#15
  • Mar 26, 2006
  • #15
For you guys that are having problems with your cars starting from the battery relocate.
1 what size wire are you using.
I had th same problem. I was using #2 wire I got from my job. That was what the problem with my car was. The wire was the incorrect one. I change to a 1/0 welding cable, which is a very fine stranded wire. My problems went away. So check your power cable on the size. You guys might need to upgrade to a 1/0 or 2/0 welders cable.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
