Starting problem
  • Thread starter Thread starter ProjectMucilage
  • Start date Start date May 28, 2008
ProjectMucilage
14
Houma, La
May 28, 2008
  • May 28, 2008
Ok, so I picked this car up for $500, and have already put over that into it with lights, 16" Pony wheels, and tires....so I' m not expecting too much. Although I' ve gotten my headlights installed (give or take some adjustment, and modification to the header panel), fuel guage miraculously started working, fixed the windshield washer, re-attached the rear view mirror, and fixed the dome and map lights, all since last Saturday. One problem I' m experiencing, and the source of the problem eludes me, is a starting problem. The car can sit for a month, and start on the first crank every time. If I drive a few miles, get the engine warmed up, and shut the car off, 9 times out of 10....it won' t re-start without a jump or booster pack. If I allow it to sit for a little while and cool off, it' ll start fine, no slow or hard starting. While it' s running, the battery guage will read one mark below center, but when I shut it off, it' s a little above the red zone. Does any know what would cause this? Both Pos and Neg cables have been changed, they were corroded as hell.
HISSIN50
34
129
May 28, 2008
  • May 28, 2008
So the issue is slow cranking when the engine is hot?
If so, look for a marginal starter cable (becoming less efficient as it heats up) or a bad starter. The same applies to the other cables, new or not. Run an extra motor-ground for duplicity.
A voltage drop test can help with the starter cable and a bench test can help with the starter. Be sure to simulate the heated conditions when testing.
Good luck.
ProjectMucilage
14
Houma, La
May 29, 2008
  • May 29, 2008
Thanks for the tips man!
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • Mindseye007
  • Aug 16, 2026
Mindseye007
