Starting Problems
FastStang 2
42
Hey guys, I need help. The engine rotates, but it won't start. It did it to me a few times already; I used starting fluid to get it going. I replaced the fuel pump and it still does the same thing. The other day, I had the engine running and it shut off. I sprayed it and got it going again. Yesterday, I tried the same thing (spraying it), but I could not get it going. :bang: Now what should I do?
Do you have a fuel pressure gauge you can hook up on the test port? Does the pump prime the system when you turn the key to the on position?
Hook up a gauge just to make sure you have proper pressure and to see if it's dropping and causing the stall.
- Jeff
Edit: did you replace the fuel filter while you were under there?
Seeing that you have chosen to hide any information about the year of your car and mods, it will not be possible to give you much help. Please update your sig in the user control panel. The sig gives us valuable information needed to troubleshoot problems, since Mustangs underwent some radical changes between 79 and 95. The wiring changed in 91 and many of the wire colors are different.
I have two different fuel pump test paths for fuel pump problems. However, since i don't know which one you need, I will post the more generic no start checklist.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
