Starting the "build" thread...
  • Thread starter Thread starter BlownStangGT
  • Start date Start date Aug 6, 2009
1 of 2 Next Last
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 6, 2009
  • Aug 6, 2009
...nothing to serious yet anyways Wish I could say I was dropping a shortblock or cams or heads on the car...but not Yet anyways
But I am going to be finally installing my front mount intercooler kit. I have a treadstone intercooler with full 3" bead rolled Polished aluminum piping. 3" Pro-M Pro Tube Mass Air meter calb. for 42 lbs injectors. Will also be installing some 42 lbs injectors to replace the current 35's in the car. Then I will be either putting on a 3.3" or 3.0" pulley. Probably going to be the 3.0" but not sure yet.
Once I get it all in it goes to the tuner. Hopefully we can figure out what the fuel problem was before. Since dropping the tank revealed that I did indeed have the 03/04 cobra tank along with pumps etc. Going to replace the battery and hopes that maybe something stupid with it might becausing problems not allowing the dual pumps to draw enough voltage to pump fuel. That or do the wire upgrade to see if that helps. Hoping we can hit 400+ hp/trq. I would like more for sure, but dont want to push it just yet. Id be happy with 425-430 at the wheels in reality haha Once she is all safe on the tune side, its off to the track with some et streets in tow
I will be taking pics throughout the intercooler install. I am starting on it Sat. Hoping to get the cooler mounted up along with some of the pipe work. I can then determine some modifications I need to make because I have the bullet intake. Cant wait to see the intercooler behind my front bumper!
Everything all boxed up....just waiting!!!!
Vortech Mini Race Bypasss
3" Pro-M Pro Tube Meter
Intercooler
Treadstone Intercooler
Proof haha
blubullett
535
Modesto, CA
Aug 6, 2009
  • Aug 6, 2009
Get a procharger intake tube for the Bullitt. Or c&l makes a nice cast one that would work with a front mount intercooler. I really want that maf you have sitting there. That is going to be a nice setup. Put a little K&N filter on the end of your bypass valve and cap the hole in the supercharger intake. It makes it sound sick.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 6, 2009
  • Aug 6, 2009
I will have to check out what the intake tube looks like from procharger for the bullet, or do you have a pic of your engine compartment? I know Ill need to put in the iat sensor and other thingie haha. The vortech intake pipe should work, just need to put the holes in for the fittings, but I think the MAF will be down farther then I want, not sure yet. Yeah, if you have a pic that would be great!!!
Yeah, I had seen some people put a filter on the bypass and some dont
EDIT
Well I did find this from C&L. Thanks for telling me to look there
http://www.cnlperformance.com/images/bullittpipe003.jpg
It looks identical to the vortech piece, so all I would need to do is weld the bung on and then thread for the iat....which I will probably get a lightning iat because they are threaded design I think if I cam correct
AmBo
1,027
New Jersey
Aug 7, 2009
  • Aug 7, 2009
You sir are correct.
Where did you pick up your FMIC setup? Was it piece by piece or some sort of a kit? This is something I've always toyed about doing but am just too lazy to do
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 7, 2009
  • Aug 7, 2009
I actually found it for sale froma gentleman on modularfords. He already had it custom made and pieced together, so I get the benefit of his hard time etc. Should be pretty easy install, only thing I should have to do that is hard is just getting the correct piece from the t.b. to MAF since I have the bullet intake
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 9, 2009
  • Aug 9, 2009
Slowly getting some work done!
I got the intake piping off along with the pp and maf. Front bumper gone. Took off old bumper support, and put new cut one on after I painted it. Got intercooler mounted up, just need to secure the bottom yet. Also got the blower end off so I can rotate it. Lightning IAT came in today, so I got that. Now just need to mark the intake piece for the new locations of objects.
Next up is to starting fitting piping and see where some stuff needs to be cut and fixed up etc. Need to size up the hole I need to cut down there the intake pipe and PP go through on the pas. side of the engine compartment as well.
Here are some pics of the along the way progress
New Bumper Support already cut...waiting to be painted...not that it mattered
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 9, 2009
  • Aug 9, 2009
New Bumper Support on
Cooler on
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 13, 2009
  • Aug 13, 2009
Got some more done on the car. Pics to come. I got the piping all mounted up the other day except for the pipe from the t.b. to mass air. Going to have to do some custom work as I have the bullet intake so it makes things interesting. I was hoping to be all done, but at least I know it is just one little thing yet till I get to get the car running again and tuned!
stangGT97
1,299
Boston area, MA
Aug 13, 2009
  • Aug 13, 2009
Looking good sir! Cutting the bumper makes me nervous but that IC looks dang sexy in there.
blubullett
535
Modesto, CA
Aug 13, 2009
#10
  • Aug 13, 2009
  • #10
Just put a 90 on the end of your intake that you have attached to the bullitt manifold to get the pipe down into the fender. It will be just like the procharger kits. You will probably have to cut the opening in the fender a little bit bigger.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 13, 2009
#11
  • Aug 13, 2009
  • #11
More pics...
Blower rotated:
Bypass
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Aug 13, 2009
#12
  • Aug 13, 2009
  • #12
Very sweet!!That is one hell of an intercooler LOL! Sick!
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 15, 2009
#13
  • Aug 15, 2009
  • #13
Thanks! I am waiting on one more piece and then I can finish it all up and finally get it running
stanggt00
371
baltimore md
Aug 15, 2009
#14
  • Aug 15, 2009
  • #14
sweet man looks good .. did not know you could just pull off the casing on the blower to turn it that will save a lot of work...
i will post some pictures here also once i get started on mine
blubullett
535
Modesto, CA
Aug 15, 2009
#15
  • Aug 15, 2009
  • #15
That may not be a shortblock or heads but it is pretty sweet. I like how there aren't very many silicone couplings, my procharger kit has tons of them. Nice smooth bends, high quality clamps. Looks good.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 19, 2009
#16
  • Aug 19, 2009
  • #16
I know nobody cares, but its getting close to being done! FINALLY!!!! Hellion Motorsports came through with a special made for them coupler that goes from oval at the t.b. to 3" circle! I am having the final work done on the intake pipe and its just a few things left. My new air filter will be here tom. from summit and just need a few small pieces from the auto store and this puppy will hopefully crank up and run on Friday! I am only praying she starts and runs and idles like a champ! Got the tender on the battery already since its been sitting for a while, cant wait! Ill get a vid of her finally firing up for sure!
SteedaGT9150
Advanced Member
Nov 10, 2004
1,351
59
68
Maryland
Aug 20, 2009
#17
  • Aug 20, 2009
  • #17
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 21, 2009
#18
  • Aug 21, 2009
  • #18
Music to my ears! Got everything installed and the car fired up and didnt skip a beat! I will get pics up tom. of everything installed back on the car. Goes to the tuners on Aug. 31st! Cant wait! Its going to be a long week to wait!!!!!
BlownStangGT
REPEAT
3,860
Lancaster, PA
Aug 22, 2009
#19
  • Aug 22, 2009
  • #19
Finished install pics:
D
darkside03gt
851
Sacramento CA
Aug 22, 2009
#20
  • Aug 22, 2009
  • #20
nice. what power pipe are you using by chance?
1 of 2 Next Last
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • dan50
  • Jul 18, 2026
dan50
