Starts But Weak.
awill94gt
Active User
Feb 21, 2017
starts, but weak.. it'll start up fine mostly in the morning after it has sat for some hours after that though it'll sometimes , sometimes more than others, crank slow, like it WONT start but catches and starts sometimes better than others.
Battery, alt are good, starter tested bad and was just changed with re-man one . gt 94 5.0 . The spark plugs and wires were done about 2 days after the starter was installed.
After both installations car started up just fine, no issues.
Maybe the starter relay under the hoold right ?
any other ideas ? 87xxxx on it now.
Slow crank and barely catching? Something is going on with the battery/charging system.
Can you inspect the terminals and misc cable connections and ensure they are tight and corrosion free? have you load tested the battery?
Not thoroughly. Will do this friday though . There is a bit of corrosion. Maybe it is the terminal.s I believe there looks to be purpl or dark colored liquid that is very thin seeping or stained.. they kinda look bad. Pic in about an hour
No Crank checklist for 5.0 Mustangs
Revised 24-Oct-2013 to update voltage drop figures.
No crank, slow crank and stuck starter solenoid problems have the same root causes – low battery voltage and poor connections. For that reason, they are grouped together.
Use the same initial group of tests to find the root cause of slow crank, no crank and stuck solenoid problems.
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a known problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
If the starter solenoid welds the contacts, then the starter will attempt to run anytime there is power in the battery. The cables and solenoid will get very hot, and may even start smoking. The temporary fix for a welded starter solenoid is to disconnect the battery and smack the back of the solenoid housing a sharp blow with a hammer. This may cause the contacts to unstick and work normally for a while.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .25 volts across a connection indicates a problem. The voltage drop tests need to be done while cranking the engine. It's the current flowing through a connection or wire that causes the voltage drop.
See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch or solenoid
100 mV Ground
0.0V Connections
A voltage drop lower that spec is always acceptable.
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
The rest of the tech note only concerns no crank problems. If your problem was a stuck solenoid, go back to step 1.
4.) Then pull the small push on connector (small red/blue wire) off the starter solenoid (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it cranks, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
6.) Pull the starter and take it to AutoZone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
Starter solenoid wiring for 86-91 Mustang
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
Electrical checks for the switches and starter solenoid
Remove the small red/blue wire from the starter solenoid. Use a screwdriver to bridge the connection from the battery positive connection on the starter solenoid to the small screw where the red/blue wire was connected. The starter should crank the engine. If it does not, the starter solenoid is defective or the battery lacks sufficient charge to crank the engine.
If the starter does crank the engine, the problem is in the clutch safety circuit (5 speed) or Neutral Sense Switch (auto trans) or ignition switch.
See the Typical start circuit diagram above for wiring information for troubleshooting.
You will need a voltmeter or test lamp for the rest of the checks. Connect one lead of the voltmeter or test lamp to ground. The other lead will connect to the item under test.
Look for 12 volts on the white/pink wire when the ignition switch is turned to the Start position. Check the ignition switch first.
No 12 volts, replace the ignition switch.
The next step will require you to push the clutch pedal to the floor (5 speed) or put the transmission in neutral (auto trans) while the ignition switch is turned to the Start position.
Good 12 volts, check the clutch safety switch (5 speed) or Neutral Sense Switch (auto trans) for good 12 volts on both sides of the switches. No 12 volts on both sides of the switch and the switches are defective or out of adjustment. Check the wiring for bad connections while you are at it.
Take a couple cups of water with a couple spoons of baking soda stirred in and por it over the battery terminals and watch the bubbles rise, that neutralizes the acid on the terminals, rinse with lots of water, than take apart the terminal connections and clean them up and tighten them down.
Sound like your battery is going bad,
Go throught the no start check list above, making sure you have a good battery/connection first.
yes. Puprle grease. Sticky in a sense though, kindascraped some to see what it was . ill follow that battery diagram above and see where we get . any possiblity of a bad EGR valve ?
Not exactly the best way to make those connections on the terminals. I could see that being a high resistance point.
Those cables should really be stripped back about 3/4" and then pinched in the channel tightly rather than have the eye crimps bolted on
Sorry, new to wiring in all general. Just did my after market HU wiring for the radio. Factory 460 mach sounds great !
as far as stripping the cables 3/4 of an inch, how would I necessarily do that ? Cut the cable about 3/4 literally ? I dont understand pinching the channel as well.
Please explain, im happy to give this a shot . Standing by and thanks for the help above all
What he's saying is that the battery vabled aren't installed on the battery terminals properly. The cables should go between the two bolts. In order to do that you would have to cut the end of the cable off.
You'd have to cut the ends and strip the plastic covering off at least 1/2 an inch back from the end. Then you'd have to loosen the two bolts and slide the wire between them under the top plate.
What you have is an electrical nightmare.
Go back and read the No crank checklist I posted; pay particular attention to the voltage drop testing information. If you don't understand it, ask and I will do my best to help you.
Use at least one of these junction point or junction blocks on the positive battery lead to join all the extra cables to the battery positive wire. Do no road kill engineer electrical work unless you have a monster insurance policy to cover the ensuing fire and destruction that will happen.
https://www.delcity.net/store/Junct..._kw=&mp_mt=&gclid=CIefiYrx0dICFUs7gQodJrABmA#
Use a standard short battery cable to go to the junction block and a short cable to connect the junction block to the starter solenoid.
Use starter cable wiring with the terminal ends already put on the wire available at the auto parts store. Don't waste you money on fancy gold plated terminals or wring parts.
Be sure that you have separate high current fuse for your stereo equipment. Smoke and fire are not part of a properly wired project.
Example - uses high current ANL fuses for 100 amps or more current. Use a smaller fuse holder and fuse if your system draws less current.
For more parts and maybe some creative ideas, see
Since you have said that you have a low level of proficiency in electrical matters, here's some help before you get started.
Automotive circuits are mostly simple stuff: a power source, a connection path, a control device, a load, and a ground.
The battery/alternator is the positive power source.
The wire and fuses are the connection path.
Control devices are switches, relays and sensors.
A load is a light, motor, solenoid, relay coil or heater element.
In automotive circuits, grounds are the return path so the electrical power can flow from the load to the negative side of the power source.
Electricity flows like water:
Voltage is like pressure,
Current in amps is like volume,
Resistance is like the kink you put in a garden hose to decrease the pressure or volume.
Power is pressure multiplied by volume or voltage multiplied by current (amps)
Digest that, and you just got the first 3 days of Electricity 101.
Use some jumper wires (connection path and ground) to hook up a switch (control device), a battery (power source), a light bulb (load). Now make the light turn on and off with the switch.
That's the electrical lab for the first week of Electricity 101.
For free automotive electrical training, see Automotive Training and Resource Site . Once you are there, select online instruction. I have personally reviewed the material and it is very good. If you are new to automotive electrical troubleshooting, I highly recommend you spend a hour or so going through the material. You'll save at least that much time troubleshooting problems.
