Startup and dying trouble...
Whenever i start my car for the first time in the morning or any other time it's sat for a while, whenever i start it up if i dont give it any gas it will die, and then if i start it up again it will die, and it will repeat this as many times as my battery has power to start it. However, if i quickly put it in gear and drive down the road a little ways, letting the motor stay at like 2000 rpm for a little while, then stop and let it idle, it will idle fine.
The idle also surges until i've driven it quite a ways, it'll die down to like 500 rpm then surge to 1500ish then back down, but then after i've driven it a bit it will smooth out to 1000ish.
Any ideas? Thanks....
See the sticky "Help me create the Surging Idle Checklist" at the top of the forum for help with your idle problems. The answer to your problem is in there.
