steeda adjustable upper control arm
  • Thread starter Thread starter autumn_again
  • Start date Start date Feb 2, 2010
autumn_again
356
Hamilton, NJ
Feb 2, 2010
  • Feb 2, 2010
i have this control arm, looking to start installing some parts i've got laying around, which will have me adjusting the pinion angle.
is this adjustable while its bolted to the car? or when they say without removing from the car you just have to unbolt one side.
i am contemplating going with the bmr adjustable upper control arm, and selling the steeda piece because it doesn't look like its adjustable while its bolted to the car, like the bmr is.
NastyStang113
1,567
Florida
Feb 2, 2010
  • Feb 2, 2010
Both of them are basically the same design. Also, note that the BMR, unless you buy the mount, does not include the stepped spacer like Steeda. The stock UCA mount is a 17mm hole and the bolt is only 14mm. So, unless you bought the mount with the BMR or the Steeda stepped spacer than you're going to get clunking. I'd recommend just keeping the Steeda adj. UCA.
autumn_again
356
Hamilton, NJ
Feb 2, 2010
  • Feb 2, 2010
i've got the upper control arm mount now, but its not on the car yet. plan on throwing the mount and anti squat brackets on.
stock ride height, what set of holes would you recommend with the new mount? i thought i read something about the steeda arm not fitting in the one set, i could be wrong though.
Suspension Rear pinion angle
  • JD1964
  • Apr 30, 2025
Fox 5.0 Mustang Tech May 5, 2025
JD1964
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Front control arms
  • Bronco Bart
  • Dec 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2025
limp
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
