  • 2005 - 2009 Specific Tech
Steeda HD motor mounts
  • Thread starter Thread starter rog
  • Start date Start date Jan 25, 2006
R
rog
Phx,AZ
Jan 25, 2006
  • Jan 25, 2006
Hi,
I'm looking for opinions from anyone using the HD
Steeda motor mounts part: 555-4005.How do they
compare to stock?If your using another aftermarket
mount please share.
Thanks
J
joshman1204
118
  • Jan 25, 2006
I'm really not sure what kind of caomparison your looking for ... There motor mounts and they work what more do you really need to know?
169stang
89
South Florida
Jan 26, 2006
  • Jan 26, 2006
I have a set of those motor mounts for sale on ebay. They work fine. I had to take them off b/c I changed out the K member which has motor mounts integrated into it.
http://motors.search.ebay.com/_W0QQsassZ169stang
I
I8URVTEC
162
  • Jan 26, 2006
I have heard different claims about the Steeda motor mounts but have not seen any dyno results so far. The idea is that they lessen the amount of power lost to engine vibration and therefore give you a few extra HP. Here is what Steeda says about them:
'The weakest link in your drivetrain may be the hydra-mounts used for mounting the engine. While they get the damping job done, they can be prone to fatigue and/or leaking under hard usage. These direct replacements eliminate the hydra-coupling, and do a better job of directing your engine's efforts to the wheels."
R
rog
Phx,AZ
Jan 26, 2006
  • Jan 26, 2006
Hi,
I not concerned with hp but was wondering if they give a
different driving experience than the stock ones.Can you
'feel' a difference with them?A possible 'fun' factor if you will
Thanks
C
creedog
61
  • Jan 26, 2006
Yes, you can "feel" a difference w/ the Steeda mounts. The engine vibration and surge of power when you get on it. Some like it, some do not. It took a while for me to get comfortable w/ the difference but now I enjoy it very much. I would NOT want to go back to stock now.
R
rog
Phx,AZ
Jan 27, 2006
  • Jan 27, 2006
Thanks creedog!
T
thump_rrr
220
Montreal, Canada
Jan 27, 2006
  • Jan 27, 2006
So by getting the BMR K Member P/N KM010 at $439.95 you eliminate the need for the $289.95 Steeda HD Engine Mounts and at the same time save 20 Lbs. in the process. Sounds like a heck of a good deal to me.
169stang
89
South Florida
Jan 30, 2006
  • Jan 30, 2006
Tis correct. BMR will also be coming out with some A arms before long. There's another 10lbs off the front!
T
Fox *Solved* Motor mount bolt question
  • TDM389
  • Mar 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 22, 2026
TDM389
T
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
D
4.6L 4v motor swap
  • DangStitches
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
squeak93
