Steeda or MM???
which caster/camber plates
  • Steeda
    Votes: 3 17.6%
  • Maximum Motorsports
    Votes: 14 82.4%
  • Total voters
    17
Thank you for purchasing Maximum Motorsports’ Caster/
Camber Plates.
Our Caster/Camber Plates are designed
to maximize the performance of your Mustang’s front
suspension. You will find many features that set our
Caster/Camber Plates apart from the rest:
• The widest range of camber adjustment in the
industry: Side-to-side reversible bearing plates double
the camber adjustment with the underhood space
limitations for camber slot length.
• Lifetime guaranteed high grade Teflon® lined spherical
bearings are used at the strut top mounting point.
Urethane bushings do not provide positive location,
and induce bending loads on the strut that reduce the
strut’s lifespan and may even break the strut shaft.
• The main plates are spaced above the strut tower,
while maintaining good hood clearance, to restore
bump travel for lowered cars.
• Our unique design places the bearing cup on top of
the main plate, further maximizing precious bump
travel with the low hoodline of 94+ cars. Bearing plates
placed under the main plate typically have 1/2” less
bump travel than our configuration.
• High grade alloy steel allows our plates to be thin and
fatigue proof. Aluminum plates must be very thick and
will un-necessarily reduce bump travel and hood
clearance.
• Patented 4 bolt X 4 bolt configuration. This means that
4 bolts secure the bearing plate to evenly spread the
load into the main plate. 4 bolts also secure the main
plate to the car’s strut tower to eliminate strut tower
bending.
• Lifetime warranty against main plate bending.
Yep MM +2 The only Steeda part I like better are their Upper/Lower Aluminum control arms with the three piece bushings :nice: Well thier 5-link is killer too but just too damn expensive :(
