  • 2005 - 2009 Specific Tech
steeda pullie install questions!
  • Thread starter Thread starter 91frppgt
  • Start date Start date Jul 11, 2007
9
91frppgt
56
  • Jul 11, 2007
i just ordered a set of steeda underdrive pullies from brenspeed. is this a direct replacement bolt on? anything i should be aware of?
thanks alot guys!
BJ1000RR
58
New Orleans, La
Jul 11, 2007
  • Jul 11, 2007
Yea, PlEEEEEEEEEEEEEEEEEEEESE remember to put the big metal washer on the bolt that is provided to start the crank pully. I made that dumb mistake and the bolt got stuck because of bottoming out. You will understand me better after you read the directions.
p.s. its a bitch to remove a broken bolt from the crank.
9
91frppgt
56
  • Jul 11, 2007
thanks man!
did you notice any difference at all with the pullys?
red05bullitgt
861
Pittsburgh, PA.
Jul 11, 2007
  • Jul 11, 2007
Sure did..After being dyno tested on both a Mustang dyno, and then on a dynojet..my car gained 10 RWHP both times..
C
CPman
129
  • Jul 12, 2007
If you can use a impact gun to remove the crank bolt, life is much easier.
K
kenaimone
85
  • Jul 12, 2007
the directions are very straight foward. i have heard nightmares about people having oil leaks due to not using the sealeant. also if you rent the harmonic balancer puller from advance auto it is much easier. i am not sure but if you use the chrystler one it is much easier.
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
