steeda pullie install questions!
Yea, PlEEEEEEEEEEEEEEEEEEEESE remember to put the big metal washer on the bolt that is provided to start the crank pully. I made that dumb mistake and the bolt got stuck because of bottoming out. You will understand me better after you read the directions.
p.s. its a bitch to remove a broken bolt from the crank.
the directions are very straight foward. i have heard nightmares about people having oil leaks due to not using the sealeant. also if you rent the harmonic balancer puller from advance auto it is much easier. i am not sure but if you use the chrystler one it is much easier.
