  • SN95 4.6L Mustang Tech
Steeda Tri-Ax Install
  • Thread starter Thread starter Beau
  • Start date Start date Jan 23, 2004
1 of 2 Next Last
Beau
3,050
San Diego
Jan 23, 2004
  • Jan 23, 2004
Well its waiting for me at home right now. Does anyone have any hints/tips/tricks/suggestions for the install?
scalder
375
Dallas/Plano TX
Jan 23, 2004
  • Jan 23, 2004
It's a very easy and straightforward install. The most difficult part a lot of times is busting loose the original shifter base from the tranny. Make sure to put a good bead of sealant down when you're installing the triax to the tranny. The triax can be pretty noisy, so you may want to wrap the handle at the base where it bolts on (and before you bolt the two pieces together) with some tape to shut it up. Then just adjust the positive stop bolts and you're good to go....enjoy! Check the search function too for lots of tips...
Beau
3,050
San Diego
Jan 23, 2004
  • Jan 23, 2004
any specific sealer that you recommend?
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Jan 23, 2004
  • Jan 23, 2004
If I remember right, you have to stop off at an autoparts store for some silicone sealer (use black in case you have to swap back under warentee) and maybe some non-permanent Loctite.
Beau
3,050
San Diego
Jan 23, 2004
  • Jan 23, 2004
oh ok great..does the silicone sealer require any "drying time" or anything like that? i was planning the install for tomorrow morning and would like to be able to drive the car to work in the afternoon.
scalder
375
Dallas/Plano TX
Jan 23, 2004
  • Jan 23, 2004
You're pretty much good to go once the install is complete...correct me if I am wrong, but I have never had to wait around...
Beau
3,050
San Diego
Jan 23, 2004
  • Jan 23, 2004
from what i've heard its totally ok to test drive it as soon as you finish the install but i'm just trying to be through and not screw it up
XTONKAX
619
UT
Jan 23, 2004
  • Jan 23, 2004
Very difficult to screw it up. This was my very first modification, and at the time I knew nothing about modifying. Just make sure you follow the instructions about the stop bolts. (Yeah, I know... can of worms there). Shift through the gears a few times before going, then have fun! I've had mine in for a couple years now with no problems.
Beau
3,050
San Diego
Jan 23, 2004
  • Jan 23, 2004
i've done a few mods already so i am not totally unfamiliar, but i have never done something like this before so i figured if people had any tricks or tips they could share them. but from what you and others have posted, it seems to be a very straightforward install
XTONKAX
619
UT
Jan 23, 2004
#10
  • Jan 23, 2004
  • #10
You don't fully appreciate the Shifter Mod until you drive another Mustang with the stocker. Have fun with it, and do try to stay focused until you can get home and play!
Beau
3,050
San Diego
Jan 23, 2004
#11
  • Jan 23, 2004
  • #11
lol i've driven by brother's BMW and its got a very short shifter, so i cant wait to have a shorter shift. i hate the long throw so much..it just feels awkward
2013 Geee T
805
Oak Park, CA
Jan 23, 2004
#12
  • Jan 23, 2004
  • #12
Step by step instructions:
http://www.stangnet.com/tech/triax.html
Beau
3,050
San Diego
Jan 23, 2004
#13
  • Jan 23, 2004
  • #13
wow i never knew that existed..thank you
StangLou
1,264
Holly Springs, NC
Jan 23, 2004
#14
  • Jan 23, 2004
  • #14
Its pretty straight forward, just the hardest part is getting the old factory one off. That itself took me 15 mins and I dinged the crap out of the base. So much for me swapping my factory back on lol. If you reuse both black rubber pieces, you wont hear hardly any noise at all. I put both back on, the a month or so later, took off the top rubber piece. There is a good bit more noise, but it doesnt bother me, plus it just feels smoother to shift since it doesnt have that extra piece of rubber adding some resistance. I also put my handle on the left side to start with, then swithced it to the right side the second time. I have left it on the right since then because it seemed to make a ton of difference for me. Made shifting a lot smoother and its just a more natural position for my hand
Good luck, and have fun with it. This is what makes our cars so fun to play with .
scalder
375
Dallas/Plano TX
Jan 23, 2004
#15
  • Jan 23, 2004
  • #15
Definitely mount it on the RIGHT side for sure...like Stanglou says, it makes a BIG difference!
Beau
3,050
San Diego
Jan 23, 2004
#16
  • Jan 23, 2004
  • #16
left side/right side of what? the shifter arm?
Teen'93stang5.0
3,560
813
Jan 23, 2004
#17
  • Jan 23, 2004
  • #17
yeah
2013 Geee T
805
Oak Park, CA
Jan 23, 2004
#18
  • Jan 23, 2004
  • #18
What kind of difference does mounting it on the right make? Doesnt it make it farther away from your hand?
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
Jan 23, 2004
#19
  • Jan 23, 2004
  • #19
i put the handle on the left side so it would be closer to reach.
here are some tips: you might need a buddy to pull off the stocker, but if its only an 03, it might be looser than my '00. another thing that was a problem for me were the stop bolts. MAKE SURE YOU SET THEM EXACTLY HOW THE INSTRUCTIONS SAY, AND BE SURE THEY ARE TIGHT!!! you may need a needle-nose plyer to hold the nut in place while you turn the bolt. the day after my install, the lower bolt came loose and i couldnt use 2nd, 4th, or reverse the whole ride home from work. i was scared going down the highway!! anyway, its a pretty easy install, except for the things ive said. if you know jack about modding (like i did) expect to spend about 2.5-3 hours on the install. and its ok to drive right after the install. oh, one more thing, make sure the car is cooled down before you tackle ine shifter, that tranny/stock shifter can get pretty hot. other than that, have fun and enjoy your new shifts!
Cars&Guitars
41
Colorado
Jan 23, 2004
#20
  • Jan 23, 2004
  • #20
Not unless you use a urethane gasket!
1 of 2 Next Last
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
Hello from Washington State!
  • Daddys Lil Filly
  • Jun 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 10, 2026
Daddys Lil Filly
D
Tkx installation problem
  • dropteeth
  • Aug 21, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 10, 2026
limp
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
