Steeda Triax making noise-rattles
my damn POS tri-ax comes loose ever month or so in one place or another. i was on a spirited drive one time when one of my stop bolts backed out and i didnt have access to 2nd or 4th. that really pissed me off. i guess my exhaust is a bit too rumbly:D
4u2nv said:
You can acquire some gasket material and create your own isolator to install between the shifter handle and the shifter rod. Maybe you've already tried that. :shrug:
Yeah I've done that, it's not gear noise. It reminds me of my first car, a 73 Toyota Hilux pickup. There was a plastic cup that fit on the ball of the shift lever that fits inside the tranny linkage rod. It would wear out and the shifter would make noise. This is not a loose knob or lever, hopefully it's not something inside the tranny.
white99gt said:
Is the noise getting worse?
If so its internal.
I should have mentioned it doesn't do it when it's cold, but as it warms up, yes it gets worse. It come and goes. It does clatter while idling in nutrel with the clutch out. When I put in the 4V and started the engine for the first time, I let the car idle with the front end elevated (pretty hi) so I could purge the air out of the cooling system. I heard this clacking sound and thought it was the engine, but it was the tranny, like it starved the input bearing of oil. When I put the car flat it didn't make the noise again. Maybe I fried something in the tranny. I wouldn't think that having the front end elevated would do this.:shrug: Time for a six speed I guess. Car only has 21K miles.
Scott
Scott
What kind of fluid?Try some gm synchromesh.It could help it out a lot..
I have Royal Purple ATF Dexron III, with only 2K miles on it. I thought you couldn't use Synchromesh in a T-45?? No throw-out bearing noise, it's pretty new, about 3K miles on it. Put a new one in along with a clutch when I swapped the 01 Cobra motor.
Scott
