ok i have the steeda triax right now and i heard great things about the mgw.. i ordered it. is there anything i should know about the instal or anything? is it the same as installing the triax? i keep hearing things about the stops or something??
Install is a breeze. MGW gives you really detailed instructions. For the stops, if you have a tr-3650 tranny then you dont need them. It tells you all in the instructions about the stops.. good choice BTW
I had the UPR shifter before my MGW, and the UPR is very similar to the steeda tri ax. I swapped to the MGW and I noticed slightly shorter shifts and a much quieter tranny, as far as noise goes through the aftermarket shifter.
