  • SN95 4.6L Mustang Tech
Steeda U/D Pullies
  • Thread starter Thread starter NewMStang
  • Start date Start date Feb 4, 2009
1 of 2 Next Last
N
NewMStang
48
  • Feb 4, 2009
I was thinking about getting STEEDA U/P set. I've been reading a lot of threads of mixed opinons over whether the mod was worth getting or not. I realize the pros are freeing up h/p and possibly better gas milage, the cons being that the install can f-up your car(if not done correctly, which seems to be quite possible). I was going to have a local shop do the install which I could provide him with the instructions with STEEDA which I think he would follow(he's an honest guy). So ultimately is this mod worth the hassle or should I just get other things like an intake, pendlum, mass air flow sensor, etc... instead?
streethorse
1,042
Dallas Texas
Feb 4, 2009
  • Feb 4, 2009
I had the steeda UDP's on my 99, and yeah they do help the car car pull
a bit harder at higher RPM's. But on my 04 I am not adding them cause I
dont race and would rather spend the $ on other things. I had a problem with
my 99 stalling out when I would just be creaping along in drive with my
foot off the gas, like pulling into my gararge or a parking space. On the plus
side they seemed to keep the air conditioner from sucking HP from the motor.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Feb 5, 2009
  • Feb 5, 2009
don't waste your money on the other mods.
The pulleys are worth a solid 5hp and are a breeze to install.
D
darkside03gt
851
Sacramento CA
Feb 5, 2009
  • Feb 5, 2009
It really depends on what your future plans are for the car. If you plan on adding a supercharger later save the $200. If you are going to run nitrous or stay NA I would get them.
Pearl02
496
Kansas City
Feb 5, 2009
  • Feb 5, 2009
+1. Very easy to install. I had them on my car for almost a yr with no problems. It took me about 45minutes to install them. Follow the instructions and you'll have no problem with them. Not a big gain in power but noticeable. Pearl02.
G
geaux
49
Atlanta GA
Feb 5, 2009
  • Feb 5, 2009
On the plus
How? It has a crank, alternator, water drive pulley. I have a convertible so I don't run the air much anyhow.
I am about to install some Steeda U/D pulleys. I was in your same boat trying to decide between the yea and nay sayers but figured since I am staying N/A they do not hurt. Wouldn't trust the cheaper ones though.
streethorse
1,042
Dallas Texas
Feb 5, 2009
  • Feb 5, 2009
I would say the reduced drag from the alt,crank and water pump drives the
AC more effieciently.
trinity_gt
3,125
81
99
Canada
Feb 5, 2009
  • Feb 5, 2009
It's all about ratios. If you undersize the crank pulley and didn't touch anything else, everything would turn slower. Adjusting the alternator and waterpump pulleys does two things: it ensures adequate charging and water flow and also allows the retention of the factory belt length.
The smaller crank pulley still results in the A/C turning at a slower rate. Since HP equals torque multiplied by RPM, if you slow the A/C compressor down, you reduce the parasitic power loss.
N
NewMStang
48
  • Feb 5, 2009
Has anyone had any issues with thier alternator b/c of these pulleys?
C
calboss281
50
#10
  • Feb 5, 2009
  • #10
Get the pullies. Less stress on motor, better in long run.
kalvick
352
Norwalk, CT
Feb 5, 2009
#11
  • Feb 5, 2009
  • #11
i had em, i got rid of them. to be honest i didnt notice a power difference before and after, and i didnt notice performance decrease after i got rid of em.
the alternator doesnt charge as much and the headlights can dim at idle.
Green&GoldGT
302
Virginia
Feb 5, 2009
#12
  • Feb 5, 2009
  • #12
I've seen some people run UD pulleys, but keep the stock alternator pulley. They claim that the tensioner will pick up the slack, but that's just "some guy's" opinion.
281CI96Coupe
233
#13
  • Feb 5, 2009
  • #13
Steeda pullies are the best. If your car is in tip top shape those pullies wont hinder anything on the motor and actually make it more efficient. It specifically says that your charging will NOT be effected, and your cooling system will be just fine.
R
RedSaleen2423
#14
  • Feb 5, 2009
  • #14
I've got a Saleen that came with the under-drive pulleys as an option and couldn't be happier. Plus, they look sweet.
N
NewMStang
48
#15
  • Feb 6, 2009
  • #15
So if I changed all the pullies except for the alternator pulley...everything would work fine and I would still see some gains? I've read about people having issues by not replacing the alternator pulley as i believe the steeda pulley is larger.
Winters98GT
1,291
224
H Town
Feb 6, 2009
#16
  • Feb 6, 2009
  • #16
you will be fine. I've put 200,000 miles on my cars with underdrive pulleys. No problems. You won't notice a difference.
Pearl02
496
Kansas City
Feb 6, 2009
#17
  • Feb 6, 2009
  • #17
As I stated earlier, I"ve had no problems with the pullies. I replaced all the pullies. I have no charging or a/c problems at all. Steeda makes the best pullies for Stangs. They will work great with your car. Some people don't like them and they have their reasons. It's up to you to decide. Pearl02.
N
NewMStang
48
#18
  • Feb 6, 2009
  • #18
Any other thoughts about the alternator pulley?
G
GettinThere
553
Central Texas
Feb 6, 2009
#19
  • Feb 6, 2009
  • #19
I installed the Steeda pulleys, except for the alternator pulley, on my car in 2003. I have had zero issues with them since.
N
NewMStang
48
#20
  • Feb 6, 2009
  • #20
So with that said, you still felt some gains, correct? I just don't want to dish out $200 and feel no gains b/c i decided against installing the alternator pulley.
1 of 2 Next Last
96-04 Steeda UDP using ONLY Water pump & crank pulley?
  • Stangg338
  • Oct 22, 2021
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2021
Stangg338
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
V
Suspension New Power Steering Rack Options - 1990 GT
  • Vix
  • Sep 2, 2020
2K
Fox 5.0 Mustang Tech Sep 2, 2020
Vix
V
R
Fox Closed PCV System, Dual Valve Catch Can
  • RTW0223
  • Dec 6, 2019
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2021
jay98
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
