  • SN95 4.6L Mustang Tech
Steeda Underdrive pulley install.
  • Thread starter Thread starter Ice Cold
  • Start date Start date Dec 16, 2005
I
Ice Cold
31
Southwest GA
Dec 16, 2005
  • Dec 16, 2005
I started the install around 5 and I would've finished, but it was too cold. All I have left to do is reinstall crankshaft pulley in the morning. I followed the advice of others and took the alternator to an auto parts store and had them remove the stock pulley and install the new pulley(no charge). Before I left I soaked the crankshaft bolt in PB Blaster. I tried to remove the bolt when I got home, but it wouldn't break loose. So I re-soaked it in PB Blaster, waited 20 minutes and it broke loose with the help of a 3ft. breaker bar. While I was at the auto parts store I picked up a Harmonic Balancer puller($15) and it made the job so easy. I know I'm not finished yet, but I think I have the hardest part behind me.
I've never done a pulley change before, but with tips from previous posts:SNSign: and the right tools it wasn't hard at all. If you can change a tire, you can do this mod. Also, did the Tunable Induction CAI install this morning and it wasn't the PITA that some had described it to be either.If you're thinking bout doing either install, go for it!
BennyBlown2v
1,233
Carmel, INdiana
Dec 16, 2005
  • Dec 16, 2005
Right after I installed my Steeda pulleys I was swapping in a cobra IRS and MM coilovers all around teehee!
Enjoy the pulleys, they are great for the price!
I
Ice Cold
31
Southwest GA
Dec 17, 2005
  • Dec 17, 2005
Thanks, I've been bit by the mod bug. Hmmm, I think I need a new clutch now! Then, I'm going to need new tires to handle the excess spinning... And if it's biting harder I'm going to need a new rear end setup so I don't snap an axle.amnit: It's not gonna stop is it?
J
Justin03GT
199
Mount Pleasant, SC
Dec 17, 2005
  • Dec 17, 2005
damn, i did the install today and it took an hour total....the alt pulley pulled right off then went right on...haha and because of my "gorilla arms" according to my buddy i was able to break the crank bolt loose with a regular ratchet...and to those who say they dont help..that BS...they did exactly what i expected...helped the engine rev faster and helped the low end grunt....great mod for the $$
SigmaPride
170
  • Dec 17, 2005
On my 99, the crankshaft bolt was extremely hard to get off. Had to get my friend with his "gorilla arms" and he used a ~2ft long steel pipe on a ratchet, but it seemed like the car was going to come off the ramps before it broke loose. Then we go to do it on his 2000 and it comes off pretty easily. We did this multiple times on mine because the first time some oil leaked out and both times the bolt was hard to get out. Maybe we just needed a bigger breaker bar, but as far as getting that out with just a little ratchet I am impressed because I don't see it happening.
BennyBlown2v
1,233
Carmel, INdiana
Dec 17, 2005
  • Dec 17, 2005
I just used an impact on the alt I had to unbolt the coolant res to get clearence, other than that it was easy. The crank bolt was just as easy when using a 2-1/2' handled torque wrench. Oil leaking usually = no RTV in the keyway, or you didn't let it cure properly before driving it.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 17, 2005
  • Dec 17, 2005
i think they are worth it specially if you advance the timing they come alive down low and up the TQ pretty good
Sable
22
Akron, Ohio
Jun 11, 2006
  • Jun 11, 2006
Does anybody have directions or a writeup on the install from begining to end?
Smoken04
Ga
Jun 11, 2006
  • Jun 11, 2006
Try this site to see if this helps you.. www.steeda.com/instructions/pulleys.htm
mwilkes
Houston
Dec 19, 2006
#10
  • Dec 19, 2006
  • #10
There's a complete how-to here:
http://www.musclecarblog.com/story-47-howto_install_steeda_underdrive_pulleys
sgarlic
3,085
Dec 19, 2006
#11
  • Dec 19, 2006
  • #11
Not a bad mod for a cash IMO. Sucks they gotta come off for supercharger apps though.
mwilkes
Houston
Dec 19, 2006
#12
  • Dec 19, 2006
  • #12
couldn't you get a smaller pulley for the supercharger to compensate for the smaller crank pulley?
sgarlic
3,085
Dec 19, 2006
#13
  • Dec 19, 2006
  • #13
Yes I suppose you could, but I think it might be difficult to figure out exactly what diameter blower pulley you would need to compensate. It may be like a really tiny pulley, and less pulley area could result in belt slip.. who the heck knows.
mwilkes
Houston
Dec 19, 2006
#14
  • Dec 19, 2006
  • #14
i imagine it would be a trial and error kind of thing, which could get expensive real quick.
There's a company, South Florida Pulley Headquarters, that makes interchangeable pulley system with a non slip pulley design, but it sounds like a lot of trouble....
Just do a turbo kit or NOS
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
