You will most likely break some of them, especially the long ones on the drivers side. They are 3/8 studs on the outside where the accessories mount, but basicly a 5/16 bolt inside the pump, timing cover and block. One or two are about 5 or more inches long.
If you can safely put some heat on them, you may get them out. Usually they break. Basicly, you will need to remove the timing cover to get them out. They bind in the timing cover from corrosion. Once you get the cover off, they should easily thread out of the block.
New ones should be available from Ford, and there are some aftermarket kits with these bolts also. Real pain. Been there, done that. Bought at least two sets over the years.
