steering column swap
yes you can , just make sure your front wheels are straight and your steering wheel is straight and u need the plastics from the tilt colum ... it takes some yanking to pull it out but it's not that hard .. then u just plug and play i had to paint the tilt platics because they were a lighter black
would like to do this swap as well can u just swap the interior portion of the column? and can i remove my ignition switch from my 93 and install it in the 97-89? thanks
