steering column ??
  • Thread starter Thread starter yakini
  • Start date Start date Mar 31, 2005
Y
yakini
28
  • Mar 31, 2005
My wheel had a lot of play in it so I took it apart as best I could without a wheel puller and I can see there is a bearing in the very top that is worn out. Anyone know if this bearing can be replaced on its own or is it just easier to replace the whole column???
blastit116
174
jupiter,florida
Mar 31, 2005
  • Mar 31, 2005
a colum is expensive so i would replace that bering if possible
ss93cobra
1,422
Wilmington NC
Mar 31, 2005
  • Mar 31, 2005
I didn't see a model year so I can't be specific, but call your Ford dealer and tell them you need a -3517- for your column.
67coupe
658
402
93
Huntsville, AL
Mar 31, 2005
  • Mar 31, 2005
Ease of replacement depends on the method used to keep the bearing in place. Is it pressed in, staked, or does a snap ring secure it? If it's pressed, you probably could replace. Snap ring would be a snap. But, if its staked you will most likely have to replace the column. Sorry I didn't offer much help, I have yet to see a fox body column.
Y
yakini
28
  • Mar 31, 2005
It's an 87 and I believe it was held in by a snap ring. thanks for the part #
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
T
Aftermarket Steering Column
  • Tas_Jak
  • Jul 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 18, 2025
Tas_Jak
T
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
