  • SN95 4.6L Mustang Tech
Steering Creak Problem - Need Help!
  • Thread starter Thread starter FalconGuy016
  • Start date Start date Dec 5, 2004
F
FalconGuy016
437
Northern VA
Dec 5, 2004
  • Dec 5, 2004
Hey
Starting this morning, occasionally my Mustang seemed to creak around corners or bumps. Just an hour ago though, I realized while driving (with the new SCT tune installed ) that it was in fact related to the steering. I turned the wheel left and right, and within a very small range from the steering wheel pointing straight, there was a definite creak in the left front wheel. It sounds almost exactly like your basic metal creak, like mabye in the hull of a boat or something, or when you walk around on a wood floor and the planks creak, but a little more mechanical. It is a bit conerning though, and the mileage on the Mustang is low (1100). Does anyone know what might be wrong?
F
FalconGuy016
437
Northern VA
Dec 5, 2004
  • Dec 5, 2004
Up! This is important please
Marks5.0!
640
San Antonio, TX
Dec 5, 2004
  • Dec 5, 2004
improper torque on the rack bushings, and/or defective rack bushings. Seems to be a common problem.
Had mine fixed back in march, dealer replaced rack bushings and torques everything down to spec and not a single noise since
Spreadman
two wheels
Houston, TX
Dec 5, 2004
  • Dec 5, 2004
If it happened all the sudden, it is probably the outer tie rod end. I've replaced 3 on mine and it sounds like a rusty gate hinge being opened quickly. $25 part from Ford.
twogts4us
4,188
12
79
Dunedin, FL
Dec 5, 2004
  • Dec 5, 2004
I'd agree with Scotty here - this sounds like tie rod ends.
hotrodnut
672
North Florida
Dec 6, 2004
  • Dec 6, 2004
My Sons' 04 GT did the same thing on the passenger side, we thought the worst that it would be the rod ends. When we jacked it up I found I could make the noise by putting force on the rack by pushing on it. The noise had sounded like it was coming from the rod end while the car was on the ground but when up in the air that was not so.
All I done to fix it was take out the rack bolt on that side and put some grease on the spacer, bolt and mounting washer and retorqued the nut and bolt. That fixed it and while it was up in the air I did the other side too just incase it decided to start making the noise. I would think since yours has such low miles that could be all it is. It's worth a try before spending the bucks on ball joints.
F
FalconGuy016
437
Northern VA
Dec 6, 2004
  • Dec 6, 2004
Thanks a lot!
DTMach1
240
Virginia Beach, VA
Dec 6, 2004
  • Dec 6, 2004
I had the same issue, the service guys cleaned and retorquedthe rack bushings...worked like a charm
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
K
Steering wobble, not typical
  • Keith509
  • Jul 6, 2019
2K
1996 - 2004 SN95 Mustang -General/Talk- Jul 9, 2019
Keith509
K
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
W
Suspension Need Advice On What To Do...suspension Problems (noise)
  • Wreckless
  • Aug 19, 2012
  • 2010 - 2014 Specific Tech
7K
2010 - 2014 Specific Tech Apr 18, 2013
nightmare00
N
