Steering Issues
  • Thread starter Thread starter Cobain03
  • Start date Start date May 21, 2006
Cobain03
996
Lexington, Ky
May 21, 2006
  • May 21, 2006
i have a lot of play in my steering wheel. once you get above 60 it gets very hard to deal with. i've done some searches on here and even refered back to my shop manual but its all a little confusing to me. i've figured out its either with the steering box adjustments or the control valve. how do i go about adjusting the steering box?
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
May 21, 2006
  • May 21, 2006
With power assisted steering, run motor and work steering wheel back and forth till you have the wheels straight and centered, shut motor down.
Loosen top jambnut on steering box on slotted screw for adjusting wormgear.
tighten screw till you feel a Slight resistance and back it off about a eighth of a turn. (you don't want it too tight or it will bind) hold this setting while locking the jambnut down.
Start motor and work steering wheel just slightly and watch the tire movement. if it is close they will move with minor steeringwheel turn.
If the control valve is out of adjustment there is a setting screw under the cap on the end of the control unit.
It holds pressure against the ballstud that your pitman are attaches to.
too much pressure on it will cause the oversteer in the power assist.
too little and it will take more steering wheel motion to get it to activate the assist.
PB
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
