Steering Moan
Kilgore Trout
Fried or Broiled ?
4,749
95
134
My steering is starting to moan a little. Does this mean it is too late to change the power steering fluid? If it is too late what is the corrective action I should take?
I searched for "power steering fluid change" and I found several replies by bcardinal that said remove return line from steering gear. How do you identify the return line?
How much and what type of fluid is recommended?
Listen man, i will tell you this from experience. It is NOT too late to change your power steering fluid. Just check and you should find the current level below MAX. No need to change it . Just add more fluid into it and after filling it up keep moving the steering wheel untill the sound is completely gone.
If all this works fineand everything turns out good. Keep an eye on the power steering level for the next 2-4 days , because you might have a leak somewhere.
