Steering Problem PLEASE HELP!!
WilwoodFiveO
108
VA
I just reinstalled my motor with my new MAC LTs and when I got finished reconnecting the steering shaft(which in itself was one huge pain in the ass) and I realized the steering wheel is perfectly upside down when the wheels are straight.My question is, is there anyway I can just make an adjustment by doing something or taking something apart in the steering wheel assembly.
Hope you can help. Thanks.
Tyler
Tyler, as I recall, the steering wheel shaft has an eccentric on one side. So you have to make adjustments at the tie rods and or rack, not the wheel itself (like we used to do in the old days).
What all did you disconnect while doing the headers?
Good luck.
Im not quite sure what you mean. For what I took off when putting the headers on, the motor was already out of the car so I unbolted the headers. as for directions could you explain to me the way or ways i can fix this problem
Just disconnect the steering shaft again, align the steering wheel in the correct position and reconnect the shaft. (Make sure the wheels are straight as well when doing all of this) You'll need someone in the car to hold the wheel for you straight while you bolt everything back up. I'm not sure what Hissin is getting at maybe he misunderstood?
