Steering question after Granada swap
  • Thread starter Thread starter 66moneypit
  • Start date Start date May 13, 2005
66moneypit
536
Northern Va
May 13, 2005
  • May 13, 2005
Ok....here's the problem. Drove my car after doing the Granada swap and it seems that it turns really sharp to the left but not sharp enough to the right. The guy working on the car said that the tie rod on the right was adjusted as far as it could go. I am pretty sure we have the right tie rod ends...I am not sure what to check.
degins
361
Texas
May 13, 2005
  • May 13, 2005
The outer tie rod mounting hole on the steering arm of a Granada spindle is about 1/2" inboard as compared to the original spindle on 65-66. 67-73 are the same as Granada. In any case, because of this the adjustment for toe out may run out as the outer and inner tie rods touch in the adjusting sleeve. The only fix is to grind or cut off 3/16" from the end of each tie rod (inners and outers). I would recommend doing this whenever using Granada spindles on 65-66 Mustang or Falcon.
66moneypit
536
Northern Va
May 13, 2005
  • May 13, 2005
That's exactly what the guy working on the car suggested. Although he only suggested doing the one tie rod on the right because the left side had enough room for adjustment. Any idea what the exact lengths for both inner and outer tie rods should be ? If I know that, I can verify this is all right before it's put back on.
HistoricMustang
2,359
Confederate States of America
May 14, 2005
  • May 14, 2005
Have you had the car alignment reset after the conversion?
HistoricMustang
www.historicmustang.com
66moneypit
536
Northern Va
May 14, 2005
  • May 14, 2005
HistoricMustang
Definitely had the car aligned... I am pretty sure it's a tie rod issue. Based on the dicussion above.
T
TT670
360
9
28
May 14, 2005
  • May 14, 2005
66moneypit said:
Definitely had the car aligned... I am pretty sure it's a tie rod issue. Based on the discussion above.
I had to trim the tie rod adjusting sleeves AND cut one of the steering stops that mount on the srtut rods down. The sleeves didnt have any effect on the turning radius, they just prevented enough adjustement to get the proper toe-in. If youve got correct toe in adjusted, then its the stop that needs trimming.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
