B beerman1378 New Member Aug 7, 2006 28 0 0 Aug 14, 2006 #1 Aug 14, 2006 #1 Whats the right kind of bushing I should use? I have an 03 GT not lowered. Should I go stock, polyurathane, polyghraphire, aluminum????
S SilverBullet00 New Member Jul 5, 2004 1,150 0 0 Wichita, KS Aug 14, 2006 #2 Aug 14, 2006 #2 Id get MM aluminum center drilled bushings. I have been dying to get a set
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Aug 14, 2006 #3 Aug 14, 2006 #3 I think the MM aluminum bushings are offset. Also, aluminum is the noisiest and harshest of all bushings. I would recommend the MM non-offset urethane ones.
squares98 Member Aug 20, 2004 852 0 17 Orange,ca Aug 14, 2006 #4 Aug 14, 2006 #4 Kilgore Trout said: I think the MM aluminum bushings are offset. Also, aluminum is the noisiest and harshest of all bushings. I would recommend the MM non-offset urethane ones. Click to expand... Once again spouting off B.S. Alum center drilled is reccommended, and are not noisy or harsh,(and yes I have had poly bushings on the car.) M.M. alum bushings are center drilled
K Kilgore Trout Fried or Broiled ? 10 Year Member Mar 30, 2005 4,749 95 134 Aug 14, 2006 #5 Aug 14, 2006 #5 squares98 said: Once again spouting off B.S. Alum center drilled is reccommended, and are not noisy or harsh,(and yes I have had poly bushings on the car.) M.M. alum bushings are center drilled Click to expand... Well, I just checked MM's website and they do offer the aluminum in both center drilled and offset so I was wrong on that one. Thanks for so rudely correcting me I still say that aluminum bushings are the harshest and noisiest of all bushings.
DTNODYA Member Dec 15, 2005 831 1 16 Aug 14, 2006 #6 Aug 14, 2006 #6 I vote for the MM urethane ... not offset though!
