I have had a problem for a while now with some play in the steering wheel. It isnt terribly bad but it is more then I like. I replaced the inner and outer tie rods recently and found fluid to be leaking out of the rack from where I removed the boots. The other day I had it up on a rack at a friends service shop and was changing the oil. I grabbed the front wheels and moved them back and forth. From the wheel to the rack is tight. However, the wheel still moves. After moving the wheel back and forth a few times I noticed the other side was moving also. I dont believe this is normal. Is it time for a new rack or do you think its just a matter of replacing the seals within the rack? Thanks
