Steering shaft hitting headers
  • Thread starter Thread starter 281pony
  • Start date Start date Oct 13, 2009
281pony
2,681
Oly, WA
Oct 13, 2009
  • Oct 13, 2009
i got my 93 coupe with a flaming river shaft in it. do they make a 351 swap specific shaft? this car had a 351 before, i believe you need to swap shafts for that conversion right? the car is still power steering, with a stock rack.
if it is swapped, should it work with a 302 still? i have bbk equal length shorty headers. the shaft is resting against it. makes steering more difficult for sure.
would long tubes likely help/make this worse? might as well get LT's if i get too involved in this.
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2009
  • Oct 13, 2009
I had longtubes on mine, and the steering shaft went through the headers. Was a perfect fit. But those 351 long tubes are a huge PITA to install..
281pony
2,681
Oly, WA
Oct 13, 2009
  • Oct 13, 2009
so the shaft goes through the headers with long tubes? i've never looked at an installed set.
i have a 302 to clarify. i believe i have a 351 flaming river stem. im just looking for the easiest way to get my steering mended. wether it be ding my header for a relief, get longtubes (kinda want them anyway) or just go back to a stock shaft.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Oct 13, 2009
  • Oct 13, 2009
we just need to trade them like we talked about.peace
john
ID89GT
1,659
18
49
Spokane Valley, WA
Oct 13, 2009
  • Oct 13, 2009
If you have a 302 you should have plenty of room.. I have bbk longtubes on my 302 and there is no clearance issues at all.
J
jerryD
1,061
Gladstone, MO
Oct 13, 2009
  • Oct 13, 2009
i have Flow tech equal shorties on mine. after i did my swap i had to heat up the header tube with mapp gas, and beat the tube in with a hammer till it cleared the steering shaft.
281pony
2,681
Oly, WA
Oct 13, 2009
  • Oct 13, 2009
ok thanks.
i think im gonna pick up a set of LT's locally and see how it looks. although the car sounds so good now with my equal lengths..
decisions decisions.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Oct 14, 2009
  • Oct 14, 2009
but L/T's are way better sounding in my opinion!Hey i have a trade for you if you want? text me later or call me.peace
john
67coupe
658
402
93
Huntsville, AL
Oct 14, 2009
  • Oct 14, 2009
You didn't mention if you recently installed this shaft.
The steering COLUMN shaft telescopes. During install of an aftermarket steering shaft, it's common for the lower column shaft to get pushed toward the firewall some, reducing header clearance. Make sure the steering column shaft is fully extended before removing/swapping headers.
bt15
129
Oahu
Oct 14, 2009
#10
  • Oct 14, 2009
  • #10
Not only does it telscope, but it's articulated. If you loosen the bolts holding the steering wheel / column in its particular alignment inside the car, you can then get under the hood / car and move the shaft to a position that may well clear all obstacles. Worked on my '85 after install of new headers. Good luck!
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
D
Headers - 302 in a 68
  • DAQ
  • Apr 4, 2024
1965 - 1973 Classic Mustangs -General/Talk- Apr 4, 2024
