Steering shaft hitting headers
281pony
2,681
Oly, WA
i got my 93 coupe with a flaming river shaft in it. do they make a 351 swap specific shaft? this car had a 351 before, i believe you need to swap shafts for that conversion right? the car is still power steering, with a stock rack.
if it is swapped, should it work with a 302 still? i have bbk equal length shorty headers. the shaft is resting against it. makes steering more difficult for sure.
would long tubes likely help/make this worse? might as well get LT's if i get too involved in this.
so the shaft goes through the headers with long tubes? i've never looked at an installed set.
i have a 302 to clarify. i believe i have a 351 flaming river stem. im just looking for the easiest way to get my steering mended. wether it be ding my header for a relief, get longtubes (kinda want them anyway) or just go back to a stock shaft.
You didn't mention if you recently installed this shaft.
The steering COLUMN shaft telescopes. During install of an aftermarket steering shaft, it's common for the lower column shaft to get pushed toward the firewall some, reducing header clearance. Make sure the steering column shaft is fully extended before removing/swapping headers.
Not only does it telscope, but it's articulated. If you loosen the bolts holding the steering wheel / column in its particular alignment inside the car, you can then get under the hood / car and move the shaft to a position that may well clear all obstacles. Worked on my '85 after install of new headers. Good luck!
