  • SVT Tech Forum
steering shaft removal
  • Thread starter Thread starter Mystic1350
  • Start date Start date May 29, 2010
Mystic1350
82
Sandy Hook Area NJ
May 29, 2010
  • May 29, 2010
does anyone have a write up on how to remove the steering shaft on a 96 cobra. i have a Haynes manual and they seem to touch on everything but the steering shaft or unless i should look other places than Chapter 10. Do i have to remove the steering gear first?
any help would be appreciated
thanks guys!
A
Art07GT
21
  • May 29, 2010
there are bolts, with nuts that need to be removed. one is at the connection from shaft to rack. one is up at the firewall. remove both of these with the steering wheel centered. pull and push repetitively toward the rack and the firewall, until its loosened enough to slide off either side. its that simple. it helps to have a friend inside the car when reinstalling. the shaft that runs out of the steering column will try to slide in upon reconnection.
hope this helps, Art
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
  • SVT Tech Forum
