Only because you keep it so "highly polished"My shaft slid out nicely. It always does!![]()
With proper lubrication any shaft should slide out nicely. Especially if said shaft isn't very big to begin with or the opening is overly large.![]()
Hey you're the one bragging about how your easy your shaft slides into your steering column.
I was just taking a SWAG that if it slid that easy into a relatively tiny hole, you must keep a high luster on it.
Err, it was what you said,... Right?
Quality??Phht! All of the how to's I've ever watched, shows that most of the "installers" just use regular old spit as a lubricant for proper shaft insertion.The key really isn't in the polished surface, Mike. It's in the quality of the lubrication used to initiate proper installation depth.
