not if you get the stock size rotors. i did b/c i upgraded to 13"streetstang03 said:dont you need new calipers for the Brembos though?
droptopponynj said:the rotors can also get warped from heavy braking from higher speeds like quick stops on the freeway.
Redsnake2 said:LOL i'm having the same problem.. I have changed the rotors<< No fix, changed the caliper <<< no fix. So now I'm changing the bearings and hub assembly. i'll see how that goes....
last thing left will be the spindle or proportioning valve..
Susky said:Before you go totally crazy, I suggest that you first double-check your wheel balance on the fronts. I've seen that a very slight error in balance can go unnoticed until you hit the brakes.
DerekStangGT said:here ya go:
Brembo quality cross drilled/slotted rotors
$129 for front rotors
http://cgi.ebay.com/ebaymotors/Mustang-GT-Brembo-Brake-Rotors-X-S-F-94-04-FREE-SH_W0QQitemZ8008497148QQcategoryZ33564QQrdZ1QQcmdZViewItem
$249 for front and rear rotors
http://cgi.ebay.com/ebaymotors/Mustang-GT-Brembo-Brake-Rotors-X-S-F-R-94-04-FREE-SH_W0QQitemZ8008497180QQcategoryZ33564QQrdZ1QQcmdZViewItem
anything is possible if they want you to buy from them againMGSTANG said:I don't believe you can get warped rotors warranted. That's a wear product and won't get replaces
david l gary said:![]()
I had the same problem.......changed everything I thought. A friend of mine said change the control arm bushing. So I installed '03 cobra control arms......Poof! fixed. Who would have thought.
