steering
  • Thread starter Thread starter jmattix1
  • Start date Start date Aug 29, 2004
J
jmattix1
  • Aug 29, 2004
I just purchased a 1989 Mustang GT convertible. When driving I get a squeaking noise out of the left front when turning left or braking. It pulls to the left slightly when braking. The rubber boot on the left side is also wet with grease. Is this a steering rack problem? Thanks
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 29, 2004
  • Aug 29, 2004
Could be....could be dust on your brake pads, could be a loose wheel bearing, could be a bad calliper, could be the dust shield rubbing on the rotor, could be a lot of things.
Lotta “could be’s”, huh?
The power steering boot is normally wet with fluid as they’re notorious for spitting power steering fluid past the seals when the steering wheel is turned without the pump spinning. You’re gonna have to just check all of those could be’s out to be sure.
HISSIN50
34
129
Aug 30, 2004
  • Aug 30, 2004
i agree with GB. too many possibilities to diagnose from a keyboard.
clean up the leaks when you get down there to check everything out, and then monitor new moisture (is there grease on the boot, or power steering/ATF fluid)?
if in doubt, or thinking of getting an alignment anyhow, a reman'd or new rack is not a bad idea. (gonna need a new alignment anyhow when done with a rack swap).
good luck.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
