stereo install ques.. not stock mach
ffr66cobra
32
replacing the head unit and not re-using anything that i don't need.. I figure all i need is....
12v constant memory feed
12v illumination feed
12v ignition feed
ground wire
any tips before i pop open the console on where i will find these???
are these wires in a separate harness from the speaker wires??
any advice would be great! thanks-- Mike
I'll be installing 3 amps, so can i take out the factory harness if it's separate from the power feeds??
Those should be the only ones you need. I think my speaker wires and the main power, ground and illumination wires were all on the same harness. What kind of amps are you installing...just curious...
Matt... all 4 of these are alone in a separate harness? I'm sure the 12v. constant and the ground would be, but... the other 12v's too? or do i need to steal them off the speaker wire harness?
