-Now for that annoying airbag light that is flashing on your instrument console! Open the dash pod and gain access to the back of the instrument pod. REMOVE the light bulb directly behind that airbag symbol. This will avoid the visual warning, but brings with it a audible alarm.
-There are two blue cased modules beneath the dash which require your attention. The first is accessible through the glove compartment. Open the glove compartment and find the "auxilliary power supply", blue case thing just above the left most corner of the opening. Disconnect the wiring and remove the box, if you like.
-The other device resides directly behind the center console, on top of the drive shaft tunnel. I did not remove this box, but did disconnect the wiring running into it. From the driver side, find the blue box and disconnect the electrical connector. This should remove any warning.
Now for the legal information:
I spoke with DMW and highway patrol about legal implications of this change. Since this is considered a "Supplimental Restraint" it is not criminally a problem. However, if you are ever selling the car, the purchaser could file a civil suit based your removing the airbag. PLEASE PLEASE check with your local DMV office before making this change.
