Sticking idle
  • Thread starter Thread starter Codydubb
  • Start date Start date Dec 1, 2011
Codydubb
149
9
18
Preston, Id
Dec 1, 2011
  • Dec 1, 2011
My idle sticks at about 12-1500 rpm about 75% of the time that i roll up to a stop and press the clutch in, if i tap the peddle just a little real quick it will drop back down to where its supposed to be. What is causing this and how to i fix it? i was thinking dirty Mass air flow sensor maybe?
pissedoff92
288
western new york
Dec 2, 2011
  • Dec 2, 2011
when the rpms come back down how does it idle? could possibly be a vacuum leak
Codydubb
149
9
18
Preston, Id
Dec 2, 2011
  • Dec 2, 2011
it idles normal once it comes back down, it has a cam so its kinda hard to tell if its completely "normal"
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 2, 2011
  • Dec 2, 2011
See the "Surging Idle Checklist for help with all your idle/stall problems. You can guess at the problem and throw parts at it, or you can use the checklist to help you find the problem quickly and inexpensively.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
4rdnut
188
  • Dec 2, 2011
Sounds like the throttle body shaft or plate is sticking since a quick stab of the pedal releases it back to normal rpm.
Codydubb
149
9
18
Preston, Id
Dec 2, 2011
  • Dec 2, 2011
thats another thing i was thinking but i dunno where its hanging up
V
vertvert
27
Dec 2, 2011
  • Dec 2, 2011
Compare tps volts when normal versus stuck high. That should tell you if throttle shaft, cable, or peddle is contributing.
2000xp8
SN Certified Technician
Aug 8, 2003
8,071
1,655
194
NJ
Dec 4, 2011
  • Dec 4, 2011
Clean the iac and check the tps, those are the things that usually cause that problem.
Reactions: bigvino
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Base Idle Reset-Accufab
  • 89notchDude
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 22, 2025
Scrapla347
