Sticky throttle
  • Thread starter Thread starter carbed 85 gt
  • Start date Start date Dec 22, 2005
carbed 85 gt
121
Honolulu HI
Dec 22, 2005
  • Dec 22, 2005
Hey I am having an occasiona problem with my 93 LX, sometimes when I cruise and go to shift in to the next gear the rpms will stay at whatever they were when I pushed in the clutch. Its not a wot problem, just enough held so if you let off the throttle the engine doesnt "compression brake" it will kinda stay at the same speed. I am told it could be a tps sensor a a TB. the pdal feels alright and the TB is an Edelbrock/BBK 70 mm. SHould I lube the ends of the shaft that goes on the TB plate?
HISSIN50
34
129
Dec 22, 2005
  • Dec 22, 2005
Do you have any vacuum leaks?
Good luck.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
