  • 2.3L (N/A & Turbo) Tech
STILL BOOST PROBLEM
  • Thread starter Thread starter TurboCoupeWHITT
  • Start date Start date Sep 4, 2004
TurboCoupeWHITT
46
Ashland,Ky
Sep 4, 2004
  • Sep 4, 2004
ok i checked and double checked all of my vacum lines i even bought a after market boost gauge to make sure my gauge was reading the right boost.... which it is only 10 psi then when ever i put the boost controller on it it will jump from 15 to 20 psi and wont hold a constant psi just when u let off the gas and make it hold what u want....... then when i finally get it set at 15 my engine bucks like its being cut from fuel or the timing is being retarded .......so im lost do u think maybe the bouncing psi could be from the spring in the boost controller ........
mr_woodster
1,314
Riverside, CA
Sep 4, 2004
  • Sep 4, 2004
what controller are you using? Do you have it hooked up right?
If you have it set up right, but it wont hold a constant boost...either you have a leak somehwere or your waste-gate is bad.
Bearded Forever
Type O Danzigative the Dark
4,927
Vinland
Sep 4, 2004
  • Sep 4, 2004
Sounds like the wastegate is sticking.
TurboCoupeWHITT
46
Ashland,Ky
Sep 6, 2004
  • Sep 6, 2004
no it holds a constant bost at 10 psi any thing after that it bounces
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
J
High idle 2003 Mach 1
  • JohnnyUtah
  • Mar 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
JohnnyUtah
J
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
K
Procharger Stage 2 - 2013 Mustang GT Minor Hiccups
  • KHills5058
  • Oct 9, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 9, 2025
KHills5058
K
K
2013 Mustang GT Procharger Stage 2 Kit Issues
  • KHills5058
  • Oct 9, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 10, 2025
KHills5058
K
