still havng problems help
91lxntch
247
altoona,p.a
well i am still having idling/surgng problems....ive tried
o2 sensors
maf sensor
plugs and wires
new tps
fuel filter
ect/'act sensors
i keep getting code 11 then for continous i get 95 34 sometimes i get 96 -66
all codes leads to a wiring dispute or a low foltage issue could the alternator cause this i have a one wire 140 alt i was going to try to hook it up 3 wire and see if it helped with low voltage ....can someone tell me if the mass/evr/fuel pump circuit all share the same ground maybe thats the problem
Ditch the underdrive pulley for the alternator is you idling voltage is below 13.8 with normal accessory load. If you normally run the A/C, have it on when you do the test.
Code 11 is computer internal self test OK
Code 34 EGR voltage above closed limit - Failed sensor, carbon between EGR pintle valve and seat holding the valve off its seat. Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the EGR valve by mouth. If you can, replace the EGR valve ($85-$95).
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Grounds:
Grounds are important to any electrical system, and especially to computers.
1.) The main power ground is from engine block to battery: it is the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the A/C compressor clutch and other electrical accessories such as the gauges. Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects.
3.) The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
4.) All the sensors have a common separate ground. This includes the TPS, ACT, EGE, BAP, & VSS
5.) The O2 sensor heaters have their own ground (HEGO ground) coming from the computer. This is different and separate from the O2 sensor ground.
6.) The TFI module has 2 grounds: one for the foil shield around the wires and another for the module itself.
7.) The computer takes the shield ground for the TFI module and runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from the battery ground wire) uses pins 40 & 60 for all the things it controls internally.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103#volt for help troubleshooting voltage drops across grounds
Codes 95 & 96 - replace the fuel pump relay & check wiring. use the above link to check voltage drops across connections.
See http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for wiring diagrams.
ok here could another problem...when i did all this work in sig i did everything at once and bam that is when this idling problem happened..i relocated my battery to the trunk and which i have a ground through the trunk and fastened to the reat frame near the bumper..also ran one from the block and fastened it to the frame near my clutch cable hold down...now on the factory neg terminal there is a small black wire that runs from it well i cut that wire and fastened the other to the fenderwell..could that one small misiing wire be a cause of this ....
Read what I posted about the dedicated ground wire for the computer. This is one of the most important grounds in the whole car.
