Still cannot get power to the fuel pump on my 66 EFI conversion. I can wire the MSD pump straight to the battery and it runs. No signs of life when hooked as directed on the Motorsport harness instructions. I have checked the wiring about 50 times, have power everywhere I think I should. 1st question, how can I determine if the ECM is powering up, and 2nd question: Does anyone other there have a valid number for Ford Motorsport tech. On the bottom of the instructions that came with my kit (on every page of the instructions) it gives (313)-337-1356. I found another number on the newer instructions for the harness of (810)-468-1356. No go for either number. The 313 number is no longer in service, and the 810 number gives some automated message from Ford. Nothing has been easy during the last 2 1/2 years of the build, but this is almost out of my league as far as troubleshooting past what I have done. BTW, I have replaced both the ECM and fuel pump relay and the insersa switch is is working (no voltage, but a solid connection when not tripped). One thing I did think of, I do not have any of the smog solenoids connected to anything, I would expect to see the check engine light lite, but I think I should still get a fuel pump on command.
