  • SN95 4.6L Mustang Tech
Stock 2V Pistons - Will they hold up?
  • Thread starter Thread starter 53BigDog
  • Start date Start date Mar 15, 2008
53BigDog
2,331
Palm Harbor, FL
Mar 15, 2008
  • Mar 15, 2008
I have a 97 GT with Ported and Polished Multi-angle Valve Job PI Heads and Cushman Motorsport (Jim's) Stage 2.5 Cams & Springs
During this rebuild I am looking at staying N/A and raising my CR to about 10.5:1. I am sticking with the Steel Crank, have read I should upgrade the stock rods/beams to H Beams.
Now looking at the pistons. The Stock is a 15cc in a 49.77cc chamber and I would love to upgrade to an 9cc-11cc but wanted to know if my 15cc pistons would first yeild the higher compression and second stand up to the higher compression? Not knowing the condition of the block yet I will probably bore a bit to clean it up. 110K on the block.
Superhereaux
chicks make me feel inadequate
538
South Texas
Mar 15, 2008
  • Mar 15, 2008
with a slightly higher compression ratio you're really not putting too much additional stress on the pistons so i think you'll be ok
putting PI heads on an older mustang will yeild a higher comp ratio, but by how much i couldn't say
CobraRed_96_GT
1,421
UCSD/La Jolla
Mar 15, 2008
  • Mar 15, 2008
about 10.5:1 compression, maybe 10.4 if it's got some miles on it. But his heads are ported, which denotes less compression due to machining.
G
Greenbird
34
  • Mar 15, 2008
Stock pistons are 10.5cc dish, and the heads will be 46cc or less. Your already going to have 10.5:1 CR. I would use the stock short block up to ~6200 rpm, and when you want more, then build a forged short block for a power adder.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Engine Raising compression on a relatively stock 302
  • keel
  • Jul 9, 2023
9K
Fox 5.0 Mustang Tech Jul 20, 2023
keel
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
Holding valves up
  • Creomod
  • Jun 5, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 16, 2023
Creomod
Specific Cam Questions that Google can't seem to answer...
  • ChillPhatCat
  • Jun 20, 2024
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Jun 22, 2024
ChillPhatCat
