Stock 5.0L headers?
  • Thread starter Thread starter Boss 351
  • Start date Start date Apr 5, 2004
1 of 2 Next Last
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Apr 5, 2004
  • Apr 5, 2004
I found some "stock" exhaust parts from an 88-90ish Mustang. But it looks like a set of shorty headers unlike stock cast-iron manifolds we see often. Did Ford put actual headers in Mustangs or did I get a good deal for both headers (sandblasted) and a stock H-pipe with O2 sensors and 4 cats for only approx. $70 US ($100 CAD). Because the same headers are being sold for around $225 CAD at a good used parts place.
Also with the 4 cats, I won't need any mufflers right? Or just cut off the last two cats and no mufflers?
Mavrick
2,264
Collingwood, ON
Apr 5, 2004
  • Apr 5, 2004
Ya, you will need mufflers.. thats not a bad deal if the o2's are still good and the cats arn't FUBAR.
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Apr 5, 2004
  • Apr 5, 2004
Hey cool, thanks... I can't belive someone was selling stock headers for $225 CAD ($170 USD). I can get full length Headman headers for around that price.
Are the stockers any good?
70stangcoupe
2,895
Winston-Salem, NC
Apr 5, 2004
  • Apr 5, 2004
Stockers, of course, aren't as good as aftermarket type headers.
I do have a set of stock headers I'm looking to sell, though.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Apr 5, 2004
  • Apr 5, 2004
I tossed my stock headers in the trash. Weren't worth diddly to me.
sleeper89
388
Toronto, Ontario
Apr 5, 2004
  • Apr 5, 2004
ditto...
boss 351 - FYI stock headers are good to around 300hp, after that they'll become a real restriction. most stock combos will give up performance by swapping in aftermarket headers.
-steve
MAC'n89Blckstng
1,012
NJ
Apr 5, 2004
  • Apr 5, 2004
yea, ford did the stupid thing to weld the pipes to the flanges on the inside. The headers on the out side look like a decent size, but once you see the inside its pathetic. The inside is about 3/4 tall by about 5/8 wide. They are TINY. Im sure someone would get really good gains from having headers installed on a stock car. The stocks are just plain bad.
sleeper89
388
Toronto, Ontario
Apr 5, 2004
  • Apr 5, 2004
i thought the same thing when looking at the stockers. i mean, how much could those pinched pipes possibly flow? then i read an article which stated the stock headers actually flow more than enough for the stock combo and that the average header swap, while it may increase peak hp will reduce power under the curve. i was still skeptical. since then i've seen numerous posts on this site and others where people actually ran slower at the track after the swap to 1 5/8" shorties. maybe 1 1/2" mandrel bent shorties would show gains, maybe not, but from my research/experience the headers aren't worth squat on a stock motor.
-steve
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Apr 5, 2004
  • Apr 5, 2004
Ok thanks guys. I will get the stock parts and worry about exhaust once I get more than 225HP lol. But I think I will skip the mufflers and just go straight to the tail pipes depending on how it sounds with just the cats
9
98SteedaStang
382
Chicago Suburbs
Apr 5, 2004
#10
  • Apr 5, 2004
  • #10
I paid $25 for used '90 GT headers and $55 for the stock H-pipe
87tbird50
44
#11
  • Apr 5, 2004
  • #11
You're right you don't need mufflers with the 4 cats, it ends up being relatively quiet.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 5, 2004
#12
  • Apr 5, 2004
  • #12
I think you'll find it both too loud, and not a very good sound to run with no mufflers. The two cats do different things - one handles the reactions for HC and CO; the other for NOx - so if you need to pass emissions you can't just cut one off.
Regardless of how the stock headers look, the note above about them not being a restriction until around 280-300 HP seems to be correct. My intentionally mild combo puts out about 265 at the crank - I LOST 3-6HP peak; minor losses throughout the curve when I swapped out my stock HO headers for FRPP 1 5/8" shorties.
willys1
1,004
New Jersey
Apr 5, 2004
#13
  • Apr 5, 2004
  • #13
I replaced my factory headers with unequal FMS shorties.I wish I kept the stock ones on and got a high-flow catted h-pipe,with a nice sounding cat back!!! I lost a good amount of low end torque Dude keep the stock headers till you get to about 290HP,then change them Having good low end torque is a blast
Ray III
586
fixin Boomhower's John Deere in Troy, NY
Apr 5, 2004
#14
  • Apr 5, 2004
  • #14
1-5/8" primary long tube headers will show a boost in low end torque on a stock motor though right? The reason aftermarket short headers don't work so well is just that, they're still short, and on top of that you reduce the scavenging effect at low RPM because the engine isn't flowing enough to get the exhaust stream up to good velocity with a larger size.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 5, 2004
#15
  • Apr 5, 2004
  • #15
On mine Ray the hp/torque loss at low rpm was negligible - 1 or 2 ft-lbs; starting about 2500 it was up to three and gradually increased up to a 6 HP/ft-lb loss at peak. Go figure. Agree with you - Long tubes should show a marked increase down low; probably not much difference up top if you believe MM&FF's latest test.
willys1
1,004
New Jersey
Apr 5, 2004
#16
  • Apr 5, 2004
  • #16
Long tubes on a 5.0,,is there really a ground clearance issue? Im not being a wise @ss,I heard they hang pretty low.
Ray III
586
Apr 5, 2004
#17
  • Apr 5, 2004
  • #17
thanks for the details Michael... I guess it's not a bad loss for a stock motor if you know you're gonna be making more power shortly after.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 5, 2004
#18
  • Apr 5, 2004
  • #18
Yup Ray - seems the crossover point is somewhere around 280-300; won't help me though. Perhaps I'll sell my pretty ceramic coated shorties, pick up another stock set (usually folks give them away) have them coated and put them back on. Mine's running too much like I want it to change anything else. Funny - going back to stock headers to pick up a few ft-lbs. Who knew?
willys1
1,004
New Jersey
Apr 5, 2004
#19
  • Apr 5, 2004
  • #19
Mr. yount,are you *****in me?? Just heat up the ones you have on there and crimp them up
Ray III
586
Apr 5, 2004
#20
  • Apr 5, 2004
  • #20
lol that sounds like a good idea.
I was talking about long tubes actually. If you put 1-5/8" longtubes on a stocker would it benefit was what I was asking...
1 of 2 Next Last
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
R
For Sale 2008 Mustang Bullitt for sale Richmond Hill, ON, Canada L4C 0S3
  • ROHDRNNR
  • Jun 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Jun 10, 2026
ROHDRNNR
R
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
