  • 1994 - 1995 Specific Tech
Stock 95 GTS Weight?
  • Thread starter Thread starter cgoebbel
  • Start date Start date May 13, 2004
  • 3
First Prev 2 of 3 Next Last
mto502
357
Ancaster, Ontario
May 15, 2004
#21
  • May 15, 2004
  • #21
95snoozer said:
my 12.95 was at a 3100 weight and 3165 with me in it.
My limited math skills are flaring up again. Are you 5 years old?
If you weigh 65 lbs I can see where you're getting some of your weight reductions from.
95snoozer
2,572
RCR
May 15, 2004
#22
  • May 15, 2004
  • #22
typo.... 3265
when i have to over and over type my raceweight because people cant understand it, I make mistakes.
95snoozer
2,572
RCR
May 15, 2004
#23
  • May 15, 2004
  • #23
mto502 said:
Maybe you should read the above mentioned weights and admit you're wrong. Maybe that will help you with your lack of understanding. They all have GTS's. Your car is a freak if it only weighed that much. Did you buy it with a few missing parts? You may have been ripped off.
Aluminum heads are suppose make my car a light weight because of an entire 40 pound weight reduction? Your arguement is getting weaker by the second.
Everything stock that came of my car was replaced with aftermarket parts, exhaust included, so there were no gains in weight loss.
The scale doesn't lie.
Anyway, just to prove you wrong I went through the trouble of doing a search and here's the weight of a 1995 Mustang GTS.
3280 LBS !!!!! Minus your 40 lb's for heads and what does that work out to ? Hmmm ... I wonder.
Here's the link so you can't say I made it up.
http://www.intellichoice.com/reports/vehicleReport.cfm/vehicle_nmb/100012822/section/specs
curb weights arent always correct on that.
I have seen them posted at 3180 3250 and 3280 depending on the article source.
what you are npot understanding is you need to TAKE $HIT OFF YOUR CAR so you arent so DAMN SLOW
mto502
357
Ancaster, Ontario
May 15, 2004
#24
  • May 15, 2004
  • #24
13.66 @ 104.6 mph with a 2.2 60 ft on street tires with a car running at 10.1:1 AF (WOT 3000 rpm and up) at 3500 lb's completely untuned doesn't seem all that slow to me.
baglock1
The Bartender
6,612
Space Coast, FL
May 16, 2004
#25
  • May 16, 2004
  • #25
I think we all understand that Snooz. What we're trying to figure out is why our cars have a roughly 100# difference off the showroom floor. Now you are claiming the least weight (3180# if I recall) and so naturally we're going to question it to find out why ours are heavier.
Ordinarilly, I wouldn't think twice as 100# can be made up in a lot of places, but I'm under the impression that my GTS came in the lightest configuration there was (with the exception of getting a special factory delete of the A/C and radio). Just to make sure we're all on the same page (i.e. not comparing AOD to T5 cars), this is what mine was optioned/non-optioned with:
95 Mustang GTS
T5
A/C
Manual Windows
Manual Locks
No Rear Defrost
Manual Cloth Seats (front and rear)
No Cruise Control
No ABS
No Spoiler
AM/FM Cassette (no CD/Mach 460)
I think that's about it but I may be missing one or two little things. Also, at the time I had a stainless steel Bassani catback (maybe a couple pounds heavier than stock but I doubt it; the stock stuff is heavy as hell) and that heavy as hell (2-3 ounces?) intake silencer removed.
Now when I weighed it, it was in the exact same configuration and still had the floormats, jack and spare, along with the trunk floor panel. Basically all that stuff people take out before racing, I left in. All that and 2.5 gallons of fuel tipped the certified military scales at 3260#. That was without me in the car as well.
Note: The military scale was used for people doing their own moves from base to base. If you move yourself (as opposed to using a moving service) the gov't will pay you based on the weight you have. Having scales that are not reading accurately would cost them tons of money every year so I'm confident that they're as accurate as it gets.
With that said, it's been my experience that the scales at the track always read a little low. Honestly, I can't ever remember seeing a weight from the track that looked right.
But regardless of the scale issue, can you see any reason why our cars may weigh so much different? I'm looking for the solution to this problem here, nothing more.
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
May 16, 2004
#26
  • May 16, 2004
  • #26
pull off the fenders and hood, the rear decklid and the entire dash........why not?
95snoozer
2,572
RCR
May 16, 2004
#27
  • May 16, 2004
  • #27
well aparently there are some variations.
we had 2 peopel here that weighed in at 3270 3280 ish with full tank.
that would go with what i say.
then you and mto weigh in where you are...
guess we are just luck and we should leave it at.
oh and yes 13s at 104 IS slow
and as i have said before. tune your car, take out the hidden weight, learn to launch on street tires and or get "tire" get a real cam..... and go get the badass numbers that your combo should make. you should go low 12s easily.
baglock1
The Bartender
6,612
Space Coast, FL
May 16, 2004
#28
  • May 16, 2004
  • #28
I leave luck to the ricers and idiots who don't do the research before building a car. There's a reason for the weight difference. Luck isn't it.
95snoozer
2,572
RCR
May 16, 2004
#29
  • May 16, 2004
  • #29
ok how about this
knowledge, research and inginuity
the luck was a joke.
my car has never had a spare and jack in it nor a strut tower brace.
with that my current mods and stereo system, it was 3240 forever. i was tired of trapping 101-102 and begin my gradual weight reduction.
I eventually got the car down to a normal weight of 3080.
I honestly believe the scale was off just by a few the 3215 night. Or maybe just extremely low gas. I weighed in at 155 myself that day before i was lifting every day in the gym and went back to 165.
I went from trapping 101-102 to 104-105 from merely dropping weight and the shortblock losening up a little.
highest trap is 105.7
you have to understand I am serious about getting every tenth of mph out of my car and I run as low as possible on gas.
mto502
357
Ancaster, Ontario
May 17, 2004
#30
  • May 17, 2004
  • #30
That kind of defeats the purpose of you giving us what your car weighed in as stock then doesn't it? The title of this thread is asking what stock GTS's weigh in at. I personally like my car in one piece. I will not be removing front sway bars etc which will only hurt the performance of my car. My car is a street car and I want to be able to drive it safely. I have removed the STB but only because it wouldn't fit under my new intake. The next time I go to the track I'll try a few runs without my spare and jack but since I don't run the car on the street without my spare I'm not going to overly concern myself with it. The same goes for my rear seat, passenger etc. I see the ricer doing that at the track all the time. A 12 second gutted civic that has no interior doesn't gain much respect me, but that's just my humble opinion, which you'll probably decribe as ignorance.
95snoozer
2,572
RCR
May 17, 2004
#31
  • May 17, 2004
  • #31
wow, you are ignorant and unable to comprehend the simplest of comments, suggestions, and responses.
you dont know what you are talking about at all with respect to what you just said.
I have a half a rear seat delete with the bottom cushion in. I carry my 6'6 friends around all the time all over town and it actually creates more room. 4 inches more leg room
my car isnt a race car, its my daily driver and my only car.
i dont really care about respect if i am ahead of you. I ran high 12 in street trim with everything in and above my normale weight.
cgoebbel
31
Tacoma, WA
May 17, 2004
#32
  • May 17, 2004
  • #32
Thanks
Taking all of the information given into consideration, I atleast have a pretty good idea of what my GTS weighs. Nonetheless I am happy to drop the weight up front with installing my new heads. Thanks again for all the input.
mto502
357
Ancaster, Ontario
May 18, 2004
#33
  • May 18, 2004
  • #33
edit
go-stang5.0
2,244
Glenview,Il
May 18, 2004
#34
  • May 18, 2004
  • #34
Quick butt in here. That intellechoice article is either off or backwards cuz I went ther to check a GT's weight and its listed as 3258 while the GTS is listed as 3280 as mentioned earlier. There is definately something wrong there. I guess the best way would be to ask a ford dealer or something. My friends m3 has curb weight listed in the owners manual but our crap ass manuals dont have that listed. Why the hell would ford leave out that simple piece of info? Thats really annoying to me.
mto502
357
Ancaster, Ontario
May 18, 2004
#35
  • May 18, 2004
  • #35
Do you have cats? Do you have a smog pump ? How about an EGR ? Were you on regular street tires to get that 1.78 60 ft? Did you delete your A/C ? Did you delete your front sway bar and countless other safety features ? I remember one comment you made to me in a previous thread. You said "if you have the balls remove the front sway bar".
That's not balls my friend. That's IGNORANCE and stupidity, and you only reinforce that ignorance through insinuating that you need to have big kahoonas. I'm sure you'll come back stating that since you've removed the sway bars there's no noticeable difference yadda yadda, but that's BS. They were put there for a reason. I'm sure you enjoy trying to drive a car that doesn't track properly. That's unsafe to yourself and everyone else on the road.
This is just the public service part of me coming out and an indication of why I charge, and take plates from people with unsafe vehicles.
If you don't have cats, smog pump, EGR and removed a $hit load of weight and ran with slicks well guess what ? You're not in street trim. Street trim is otherwise known as street legal and driving a car that still has all the safety features the factory put it out on the road with. Get off your high horse. Your times mean crap just like a gutted Hondas times mean crap. That's just my ignorant opinion though.
My car is a fully legal street car, not half of a car.
...of course I don't know what I'm talking about so this is just another premeditated rambling.
__________________
95snoozer
2,572
RCR
May 18, 2004
#36
  • May 18, 2004
  • #36
QUIT YOUR CRYING
you are trying to quote me on stuff i havent said. i went 13.1 on street tires at 105.7 with my smog pump ac power steering.
how many times am I going to list my weight reduction that you fail to read? I am not going to do it again. I have listed everything that is out of the car and there are no secrets.
sway bar isnt a safety feature... its a handling feature. if a car that handles poorly is unsafe then thast because you dont have the ability to handle the cars handling characteristics. hence the "balls" comment. yeah it handles differently, it handles like a muscle car does, loose. but i dont care because it yanks the front up so hard.
mto502
357
Ancaster, Ontario
May 18, 2004
#37
  • May 18, 2004
  • #37
This just gets better everytime you post !
Let me use an anology here.
If a car handles poorly due to the removal of OEM parts that were originally designed by engineers for better handling characteristics, the removal of these parts wouldn't take away from the safe road manners of that particular vehicle ? That wouldn't make it unsafe ? Sounds a little contradictory doesn't it?
In your infinite wisdom you've deemed that this is simply OK as long as you're brave enough (have the balls, as you put it) to think that you can handle that car safely. You drive this car on public roads with substantially important handling components missing from that car, and take it upon yourself to endanger others on the road?
I'm not putting words in your mouth. You've had the edacity to make those rediculous comments on your very own. With your reasoning, "you don't really care since it yanks the front up so hard". You said that, not me.
This is your justification to reduce the safe operation of that vehicle.
With your archaic mind set I suppose you think it's safe to ride a motor bike all over town doing wheelies. As long as you can handle that bike there shouldn't be any problems right? I suppose that would be my anology once you've sifted through the rest of my crying. Your arguement is redundant and bears no truth in the reality that your car is not safe. Your car would not pass a safety inspection because a handling component has been removed/missing thus making the car unsafe, period.
As for your "repeating what you've taken off your car" comment, you speak as if I know you and your car and have read every thread you've ever posted on this site in reference to your weight reductions. You're wrong.
Enough said !
95snoozer
2,572
RCR
May 18, 2004
#38
  • May 18, 2004
  • #38
for someone in law inforcemant, you dont know the laws.
you must not know the first thing of a drag setup.
I told you where my weight reductions were. there WAS a thread with EVERYTHING in it that you saw.
and yes your right i should have a car where the nose stays completely down on the launch because we wouldnt want our car to have any weight transfer now would we
I am done with this. no more point to this thread. You are a hopeless cause and you are just going to criticise what you have no knowledge about. But i feel the need to help even though you probably wont except any because its your "street car" and you dont want to be a race car like mine sure is.
oh and here is a thread for you so you can criticise everyone else.
who on this forum runs no sway bar?
for you, my reductions
swaybar- you obviously are going to leave this.
STB- you have this gone
smog pump - aparently you are keeping this you need it with cats
dog bone remove this! it hurts nothing
trunk carpet and board- i had no choice
rear seat delete- my friends who are 6'- 6'6" are right here and say they prefer the rear of the seat gone. it gives them 3-4 inches more room leg room and depth to the seat. Maybe you shoul look at a rear seat delete before you speak poorly of it.
i am on stock ponies.
floormats and windshield wipers come out at the track. If you are a few ttenths form 12s this will help you. i didnt take these steps to run 12s as I had schoolbookc and all kinds of crap in my car. an extra 25-30 pounds than normal.
drain the fluid out of your windshield wiper fluid reservoir for track trips. its 10 pounds on the very front of the nose.
there are a few little things that add up to only 5 more pounds.
I run on a 1/4 tank or less of gas always.
stock heads stock k membernormal raceweight is 3080
mto502
357
Ancaster, Ontario
May 19, 2004
#39
  • May 19, 2004
  • #39
I've noticed that your new sig states that your goal is to prove others wrong. How ironic.
Before proving anyone wrong you'd have to have a clue yourself.
That's law Enforcement with an E and I have a fairly good grasp on the laws since you've mentioned it. Anyway, this was a fun thread while it lasted but I agree with you. It has become pointless now. I'm speaking to ignorantly deaf ears
Drag setups are for the drag strip and street setups are for the street, as per my meaning of that statement in my above posts.
95snoozer
2,572
RCR
May 19, 2004
#40
  • May 19, 2004
  • #40
wow, somone has never heard the term street/strip
wow you are a little girl when it comes to modding your car.yes I am using name calling because that is my term that i often use for people who are AFRAID to do things that will make them faster.
or I could be honest and just use the universal term
"p u s s y"
  • 3
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
M
Gt40p headers
  • Mike3
  • Oct 14, 2025
1994 - 1995 Specific Tech Nov 1, 2025
Blackhawkxx
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
P
Engine Help 331 stroker
  • pdmount
  • Feb 19, 2026
Fox 5.0 Mustang Tech Feb 21, 2026
pdmount
P
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
