Stock Balancer Looking Wobbly?
I have an aftermarket perf. balancer from summit on mine and I would not recomend it. the dia. is larger and the water pump lower bolt housing had to be clearanced, and the balancer is narrower so the pulley needed to be shimmed. It fit more like a generic balancer than one made for 94-95 5.0 as advertized. I'm gonna switch back to oem.
brentwoodboy said:
I've seen one for around 80 and its aftermarket... Any install tips?
Steps to pull the balancer.
Disconnect the battary
Pull the electric fan out
Take off the belt
Take off the crank pulley
Put the car in 5th gear and break loose the balancer bolt
Take the bolt out
Get a balancer puller and pull the balancer off
Put some gasket sealer on the balancer input
Put the balancer on with a rubber hammer but don't hit the outside of the balancer.
Put the bolt on and crank it down and pull it to the crank
