  • 1994 - 1995 Specific Tech
Stock Cam or FTI?
  • Thread starter Thread starter WhiteSN95
  • Start date Start date Aug 31, 2004
W
WhiteSN95
142
  • Aug 31, 2004
Hi, my mods are in my sig and i will be adding a 100 hp "Dry" Zex nitrous kit to my car. i will be upgrading the fuel system and ignition as needed but my question is about the cam. Should I leave the stock cam in the car or should I have one made by Ed Curtis over at FTI. This car is going to be basically a street car but will see the track occasional. The spray is for some extra fun and will be used when needed. Thanks in advance
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 31, 2004
  • Aug 31, 2004
Give Ed a call and ask him to see what he says. I would leave the stock cam in there my self unless I was going to upgrade to a better head that would appreciate a custom cam. That's just me tho.
Joes95GT
3,132
Delaware
Aug 31, 2004
  • Aug 31, 2004
You've got a great trans set-up, but I'm thinking that Ed would want to see more converter with that much nitrous. Because the heads have been worked on, he's probably going to want to know the flow numbers, valve sizes, port sizes, etc. I can almost guarantee you that you're valve springs will be inadequate as well.
It's all money.
Joe
W
WhiteSN95
142
  • Aug 31, 2004
These heads were pulled off of a Race car and sent out to a shop. The valve springs are good up to .600 lift and 7000 rpms
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 1, 2004
  • Sep 1, 2004
Yeah like Joe said, to accuratly design a custom cam you'll need accurate flow #'s through out the whole flow test. Just calling ed and saying "I have ported and polished gt40 heads" isn't gonna cut it.
I'd use a bigger injector like a 30lb especially for dry nitrous. Get yourself a 255 high pressure pump.
Joes95GT
3,132
Delaware
Sep 1, 2004
  • Sep 1, 2004
Lift figures help a bit.
Spring pressures determine RPM. Stock GT springs are "good" to 7000 RPM, the question is just for how many times. When the valves are opening 40 times a second, the springs take the beating.
What are the spring pressures?
Joe
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Sep 1, 2004
  • Sep 1, 2004
Huh? I wouldn't take stock GT springs above 6000 even for one revolution .
Silly crack smokers...
Dave
Joes95GT
3,132
Delaware
Sep 1, 2004
  • Sep 1, 2004
Dave
I agree with you Dave. A few weeks ago, I was informed that the early 94 T4M0's did indeed have the rev limiter set at 7000 RPM. This was confirmed by both Paul and Jake. I actually thought they were mistaken.
The things that make you go "hmmm"....
I like your sig too...
Joe
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
N/A build on fresh stock 302
  • djcarrot
  • Wednesday at 8:56 AM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 4:12 PM
AeroCoupe
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
