stock cam specs?
  • Thread starter Thread starter Ozz
  • Start date Start date Jan 24, 2007
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Jan 24, 2007
  • Jan 24, 2007
Anyone wanna point me in the right direction?
vikingpower
656
CWU Ellensburg, WA
Jan 24, 2007
  • Jan 24, 2007
I think its 206 @ .050, .444" lift with 1.6 rocker, 116 lobe sep.
89streetbeast
365
horton,ks
Jan 24, 2007
  • Jan 24, 2007
advertised duration intake: 266°
advertised duration exhaust: 266°
intake @ 0.050: 204°+
exhaust @ 0.050: 204°+
valve lift intake: 0.444''
valve lift exhaust: 0.444''
lobe sep: 116°
thats all i could find. those are at factory rocker specs.
Ozz
3,514
66
109
Canton, MI
Jan 26, 2007
  • Jan 26, 2007
Thank you guys
MadDAWG
25
Michigan
Jan 27, 2007
  • Jan 27, 2007
I saved these from a post I saw on corral. The guy checked his cam from an 87GT. Keep in mind that factory cams have a pretty wide tolerance so they can vary somewhat from this.
.278"/.277" lobe lift
.006" durations & timing events
266/264
IVO 16 BTDC IVC 70 ABDC
EVO 67 BBDC EVC 17 ATDC
ICL 117 ECL 115 (116 LA with 1 degree retard ground in)
0.050" durations & timing events
211/210
IVO -9 BTDC IVC 40 ABDC
EVO 41 BBDC EVC -11 ABDC
F
FullAuto
157
Midwest City, Ok
Jan 28, 2007
  • Jan 28, 2007
The '87-'88 cams are 266/266 @ .006. The '89-up cams were 276/266 @ .006. Ford never rated them @ .050. The 204+ @ .050 is just what other people have measured.
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Jan 28, 2007
  • Jan 28, 2007
There are more than one OEM cam used on the Mustang.
F
FullAuto
157
Midwest City, Ok
Jan 28, 2007
  • Jan 28, 2007
So then list them all and their differences.
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Jan 28, 2007
  • Jan 28, 2007
I don't know the specs...i only know FOrd changed the camshaft. Once was in '89 to quiet the driveline and again around '91 or so. The differences are probably too small to be important.
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Y
Dash cam
  • yankeyfan02
  • Sep 15, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 18, 2026
horse sence
