stock cam specs?
Here is some of the info I have...
Stock 87-93 Cam Information:
Lift is .444*/.444* - Advertised @ 266*/266* until August of '88, then it went to 276*/266* .
Duration at .050" varies and ranges from 204*+/204*+
85-88:
Lift: .278 intake, .278 exhaust
Duration: 266 intake 266 exhaust
Overlap: 36 degrees, 9.04 factor
Lobe Center: 115 intake, 115 exhaust
89-90:
Duration: 276 intake, 266 exhaust
Overlap: 39 degrees, 19.51 factor
Lobe Center: 116 intake, 115 exhaust
91-95:
93-95 Cobra:
Lift: .282 intake, .282 exhaust
Duration: 270 intake, 270 exhaust
Overlap: 33.5 degrees, 15.24 factor
Lobe Center: 115 intake, 121.5 exhaust
1985-08/1988
I.O. 17 BTDC / I.C. 69 ABDC
E.O. 67 BBDC / E.C. 19 ATDC
08/1988 - 1993
I.O. 20 BTDC / I.C. 76 ABDC
There is more in my signature...
wow ... but i have a question or 2 ...
91-95:
91-95:
is the 115 exhaust lobe center actually the lobe seperation angle, or is it 115 degrees before TDC?
i assume the 276 is the full duration, not the duration at .050?
what does the "19.51 factor" mean?
