Stock crank pulley specs?
TheShagg
67
I am looking to use a 94-95 pulley on a pre-94 HO engine, mainly because of the decreased depth. (I actually plan on putting a trigger wheel and a spacer between the balance and the pulley for stock belt alignment).
I'm looking for two specs, if anyone can give them to me, to know if the pulley will be usable.
1) Diameter, measured from the "tops" of the grooves, or the "bottoms" of the grooves, or, if you can't measure that, I could live with the diameter of the "rails" that keep the belt from coming off the front or the back of the pulley.
2) Will the 94-95 pulley mate with the pre-94 harmonic damper? Is the 4 bolt spacing the same, and is the center-hub hole the same diameter?
Ideally I am hoping the two pulleys are identical except depth.
Thanks!
I have the stock pulley in my hand as i gve you the measurements. Diameter is 6 7/8" lip to lip.
2)
Don't know
Center opening is 1 5/8". Bolt spacing center to center is 2 7/8" through the center line of the pulley.
Thanks![/
Now if someone has a '94-95 crank pulley that is 5.5" - 5.75" or knows where I can get one please let me know.
I assume that measurement would be measurement A on this picture?
