i like the intake grady is running but i looked up the specs and it said hp range was 4500 -7000...i want a lower hp band...i think
the more reserch i do the more undecided i get.
Well Trav
Those rule of thumb sayings are ... not always as they seem
At face value ... that statement looks like .........
the power band is gonna be between 4500 and 7000
I selected that intake for its ability to hold the power up in the higher range
however
1) I went self tune to help offset things
2) I selected LT's over Shorty's to help offset that intakes soft low end
3) I went custom cam to have a choice of efficient power band
At the time of all those decisions ..........
Most of the internet peeps poo pooed the Edel RPM for street use
also
Very few peeps at that time were using LT's for street use
also
Self tuning was all but unheard of as it was in its infancy
also
AND... IMHO ... This is the most important ... also
I had Paul Riva's dyno curves plotted in an Excell file
I've tried to show peeps over and over ............
The ability to compare dyno curves allows you to easily see ..........
Just how the combo is gonna behave
Sure, at that time ..........
there were several combos that were at 300rwhp give or take
but
only a handful had torque curves that looked like Paul's
The common trait of those few combos was a cam by Ed
Please, Please understand my meaning here Trav
I ain't trying to brag or show I'm smarter than most
but
If your do what most do
... you'll get what most got
Each decision had some logic behind it based upon .....
things I knew to be true
as for the things that were unknowns ............
Like why Paul's combo showed more desirable torque curves
A bit of research on my part
and
Then those unknowns were moved to the list of knowns
That way .... ALL combo decisions could be based upon knowns
How great is it to have other's results
good or bad
easily available to you with a simple search
you keep the good
and
avoid the bad
Hope this makes sense
Just to show that while my intake choice was intended for higher RPM
A plan was put in place to lower it a bit
thus
Allowing me to take advantage of its top end
and
NOT suffer all that bad ... if any
on the lower end
In the end ... the plan turned out better than I expected
Grady
