  • SN95 4.6L Mustang Tech
Stock Injector Size
  • Thread starter Thread starter Malevolyn
  • Start date Start date May 3, 2006
Malevolyn
18
Lakeland, FL
May 3, 2006
  • May 3, 2006
Anyone know the stock injector size on a 96 Cobra? I'm replacing mine and I'm thinking about going a tad larger.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 3, 2006
  • May 3, 2006
1tirefire
118
Northern Bay FF/SS
May 3, 2006
  • May 3, 2006
urban96 said:
24
loosescrew79
313
  • May 4, 2006
Do you really need a bigger injector though? I thought it wasn't really benefitial unless you had a blower or a big power adder
Malevolyn
18
Lakeland, FL
May 6, 2006
  • May 6, 2006
Would 30lbs. be so bad? I'm going to be doing some intake work. (CAI or FIPK, p&p intake, bigger MAF, etc.)
jstreet0204
939
Winston Salem, NC
May 6, 2006
  • May 6, 2006
Honestly, you aren't likely to gain anything by either the MAF or the injectors. These are mods that you upgrade when your power level requires it, not to make power. Unless you KNOW that your future power level is going to be beyond the level of the stockers, you are simply spending money on something you don't need. You will require a tune for the injectors and the MAF also so consider that money as well. You should really datalog after your upgrades to see the duty cyles of the injectors and the max voltage on the MAF, THEN decide if you want to upgrade. Ultimately it is your money, so spend it how you wish.
billfisher
1,296
huntsville, AL
May 6, 2006
  • May 6, 2006
i added the larger/higher flowing components because the intended level will reach above 400fwhp.i'm going to have to go with larger injectors at that point, but not until. put an adjustable fuel pressure regulator and up it a little when you need to. as your power level reaches the limit then upgrade. you'll need a wide band and some way of logging A/F under load. FPR's run 75 bucks. go to BLUEOVALENTERPRISE on ebay. they sell billet. i have one. you can adjust it without removing the vacuum line.
FWIW
laxdman20
95
Va.
May 6, 2006
  • May 6, 2006
I agree, when your power level increases beyond what your stockers can do, then upgrade. Otherwise stick with what works. But if you do need some, I have some 38#'ers in the classifieds.
Dan_Soprano
7,410
54
129
Jacksonville, FL
May 6, 2006
  • May 6, 2006
and I have some stock 04 Cobra 39's and maf in the classifieds also.......
billfisher
1,296
huntsville, AL
May 6, 2006
#10
  • May 6, 2006
  • #10
i sure wish i knew that before i bought all this crap this week.
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Fuel Fuel injector cleaner?
  • Creomod
  • May 29, 2026
Fox 5.0 Mustang Tech May 30, 2026
evintho
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
